Head Gasket Replacement
geordie
576
Soon I'm going to have my block stripped, intake off, oil pan off, water pump off and timing chain cover removed. Does anyone think that I should remove the heads for inspection or replacement of the head gaskets? This motor was rebuilt about 10,000 miles ago. The compression ratio is 11:1, does anyone have a head gasket recommendation?
I removed the engine to clean up the engine bay, fix a bunch of minor issues and problems, replace some parts, but mostly to gain experience.
I'm not intending to pull the heads (I don't think), remove pistons, cam etc.
