Head swap, on 19/lb injectors? Will there be a problem?
Lynx331
308
Chicago IL
Hey guys im planning on doing a head swap on my car. I have converted to mass air and im using stock injectors with the stock MAF meter. My question is if i was to swap in heads, and a 255lph fuel pump... Will there be an issue with fuel? Since i will still have the stock mass air meter, and 19/lb injectors? I would only run it like this for a month or 2, once i get more money to buy a bigger mass air meter and bigger injectors. Also when i did the head swap i would most likely install a cam and 1.7 roller rockers, dont know if that makes difference. So would i be able to run my stock injectors and maf meter, with those mods? What do you guys think? Is there a chance i could damage my motor somehow from it leaning out?? Thanks for your help guys.
