  • SN95 4.6L Mustang Tech
Header Gaskets..what to use
  • Thread starter Thread starter ZIncGTSTANG
  • Start date Start date Jan 31, 2007
ZIncGTSTANG
34
  • Jan 31, 2007
I'm about to put SLP lt headers on my '03 GT but am unsure which gaskets to use. I have read that many people say to not use the gaskets that came with the headers. I have also read that some people reuse the stock ss ones. Anyone know how good the SLP gaskets are? Did I pay for good gaskets or just good headers. Also heard that some people double up the old gaskets with the new ones. All of those that have installed headers, what did you guys use?
I
Invictus
22
  • Jan 31, 2007
i used the compressed fiber ones that came with my BBK LTs and they were absolute ****. right out of the garage i had major leaks. bought some copper ones from SUMMIT (i think they were around 60-70) and immediately, problem fixed along with a noticeable performance gain.
ZIncGTSTANG
34
  • Jan 31, 2007
Exactly what I dont want-a gasket leak after I get all the bolts tightened down. Ill check out summit. Those are pretty expensive gaskets.
T
TGJ
1,049
  • Jan 31, 2007
Percy's Dead soft header gaskets or new Ford OEM ones( not FRPP/SVO header gaskets )
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Jan 31, 2007
  • Jan 31, 2007
just get some copper ones from summit and the stage 8 locking header bolts. dont know aobut the ones that come with slp. i know jason86 used them on his car and i havent heard any problems with it yet. might wanna PM him
jivepepper
776
Under a Sombrero. in WV.
Jan 31, 2007
  • Jan 31, 2007
I reused my stockers and stock studs, on a cheap set of used macs. Its been 7months later and still no leak.
ZIncGTSTANG
34
  • Feb 1, 2007
Thanks for the replies everyone. I've heard good things about the Persy's dead soft from summitt, but haven't really heard the reason for them being good. I was thinking about getting the FRPP ones, but they're only $15...price scares me. The SLP gaskets that came with the headers run $30 and seem like they would form fit alot better than copper/ss gaskets. The ford gaskets also cant really be damaged during install and are dependable on stock manifolds. Maybe I am worrying too much. I just don't want to do this twice right after I finish.
ZIncGTSTANG
34
  • Feb 1, 2007
Here's a shot of the gaskets.
http://i116.photobucket.com/albums/o21/03zincGT/SLPheaders012.jpg
I think I'm just going to go with new ford gaskets because I haven't really heard much about the slp gaskets and everyone that gets mac or bbk says their gaskets suck.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 1, 2007
  • Feb 1, 2007
The stock SS gaskets are not bad, but if you only want to do it once use the Percy's seal 4 good, or Cometic MLS.
The Percy's work so well because they conform to the un-true surfaces of the header flange and because the gasket is solid, it cannot blow out.
Percy's# 66033 Ford 4.6 2-Valve 1.625" Round
Don't use those POS gaskets that come with the headers.
'01 Steed
482
Michigan
Feb 1, 2007
#10
  • Feb 1, 2007
  • #10
OEM's with no issues.
Of course, header flange quality needs to be considered. Hooker may be a bit better at controlling flatness than other makers.
gtvertsoon
154
Port Tobacco, MD
Feb 1, 2007
#11
  • Feb 1, 2007
  • #11
I originally used the stock ones since they are metal. The passenger side leaked so I pulled it apart AGAIN and used a fel-pro gasket from autozone. Together with some silicone gasket maker, worked like a charm and you don't have to retorque the bolts because the silicone holds them.
C
comporange04GT
110
#12
  • Feb 1, 2007
  • #12
I used the Bassani gaskets that came with my headers and haven't noticed any leaks. I don't think that I would double up headers gaskets.
ZIncGTSTANG
34
#13
  • Feb 1, 2007
  • #13
I've heard of almost all the header gaskets in here leaking or blowing out on one or more occasions. I think the leaks and blowouts are probably just from people messing up during the install by not tightening the bolts enough, overtightening them, or tearing the gaskets. I think Im just gonna go with new ford ones. Thanks for the replys. Every gasket thread I read, everyone has mixed opinions on what to use.
hotmustang331
2,967
Bastrop,TX
Feb 1, 2007
#14
  • Feb 1, 2007
  • #14
^Exactly. I used the gaskets that came with my BBK LTs and they worked leak free for the 6 or so months I had the headers on. But the guy above a few posts had leaks right off the bat. Perfect example.
NOW I have percys dead soft aluminum gasktes....we will see how they work tomorrow
foncarelli
156
Feb 1, 2007
#15
  • Feb 1, 2007
  • #15
x 2 ... worked like a charm so far.
ADRENLN
2,342
NJ
Feb 1, 2007
#16
  • Feb 1, 2007
  • #16
im useing the slp gaskets...im gonna change them though when i do the block swap in the summer. not sure if they are leaking, but i have a leak somewhere in the exhaust. i think my leaks are from the bolt up magnaflow mufflers though.
steveb24
555
wilmington, DE
Feb 2, 2007
#17
  • Feb 2, 2007
  • #17
u guys all using the stock studs/ nuts? u put some loctite on them or just tighten them real good? i wouldnt want to be tightening them all the time.. acctually.. never.
hotmustang331
2,967
Bastrop,TX
Feb 2, 2007
#18
  • Feb 2, 2007
  • #18
I actually used anti sieze with the stock studs/nuts . No problems.
I used it on the side of my new headers....but forgot to on the pass side LOL. But being SS bolts I should be ok.
Any 1 find any decent blackfriday sales for Foxbody or car stuff?
  • rednotch
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 19, 2025
rednotch
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
