  • 1994 - 1995 Specific Tech
Header Ground Clearance
  • Thread starter Thread starter final5-0
  • Start date Start date Oct 5, 2007
1 of 2 Next Last
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 5, 2007
  • Oct 5, 2007
I measured the clearance between the ground and various points of the
exhaust system on my 95 GT
The car has not been lowered
The headers are Mac 1 5/8 LT's
From the ground to the lowest point which is the collector flange is 4 3/8"
From the ground to the bottom of that long channel rail that runs down
each side of the car is 6 3/4" and the measurement point was taken at
the extreme front of the channel rail
From these measurements you can see the lowest header point which
is the collector flange hangs 2 3/8" below that channel rail
All other parts of the exhaust system are higher than that flange point
Grady
Bosko5.0
1,067
longwood, FL
Oct 5, 2007
  • Oct 5, 2007
I know in the past that many people wanted to know how much ground clearance there was with Lt's. And there it is.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 5, 2007
  • Oct 5, 2007
It would be great to see others post up the same measurements
with shortys.
Notice the distance was given about how far the LT's hang below that
channel rail. This is the most helpful measurement
If others would give that same measurement .......
We would know the difference between the two types of headers
as opposed to
The amount of clearance to the ground which can be different from
car to car due to suspension sag and drop.
Grady
juiced_94gt
1,143
Southern California
Oct 6, 2007
  • Oct 6, 2007
my car is lowered with eibach pro-kit's and has BBK 1 5/8" LT's and it doesent bottom out on ANYTHING.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 6, 2007
  • Oct 6, 2007
Mine doesn't either
Now ... get out there and get us some measurements
Your input here would give us the difference between Mac & BBK
Please
Grady
rj95svt
422
Hayden, AL
Oct 6, 2007
  • Oct 6, 2007
I'll measure mine as soon as I get home from work this afternoon but I bet my stock shorty's and flowtech O/R X pipe hangs down lower than that.
With the stock ride hight my car drags on everything!
rj95svt
422
Hayden, AL
Oct 6, 2007
  • Oct 6, 2007
The lowest point on my exhaust (exhaust clamp on front tubes of x pipe) is 3 1/4" off the ground. The same point is 3 1/2" lower than the pinch rail. The clamps are turned sideways as much as possible to get as much clearance as possible. If I was to weld the tubes on and loose the clamps I would gain about 3/4 of an inch more clearance.
My cars stock ride hight measured at the same point as Grady's is 6 1/2- 6 3/4". I had a hard time measuring the due to a small hole just behind the tire but I figured it was close enough.
I could actually gain clearance going to long tubes!
Note to anybody thinking of buying a Flowtech X pipe DON'T!!!!!
SublimeRT
230
Clarksville, TN
Oct 6, 2007
  • Oct 6, 2007
I'll measure mine here in a few. I have BBK 1 5/8 LTs and BBK OR X pipe, the car is lowered with FRPP B springs also. I'll take a pic too I guess.
Edit: Ok, went and measured. Lowest part of the header was 4" from the ground. The channel was 6 1/2", if I measured it at the same place as you guys. We're talking about the channel at the rocker panel where you put the factory scissor jack, right? Not the front frame rails where subframe connectors would be welded on? I didn't get a pic but I guess it's not really needed, the measurements suffice.
Stanger007
2,015
Baton Rouge, LA
Oct 6, 2007
  • Oct 6, 2007
Channel: 7"
Mac 1 5/8 LT Flange: 4.5"
Convertible X-Brace: 4"
Anyone sitting higher than me?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 6, 2007
#10
  • Oct 6, 2007
  • #10
Stanger007 said:
Channel: 7"
Our results are very close
Wow ... that vert brace is actually lower than your exhaust
Grady
Bosko5.0
1,067
longwood, FL
Oct 8, 2007
#11
  • Oct 8, 2007
  • #11
Grady
Wait till you hear mine I,ll take measurements later today.
Iam confused of this channel rail???? the subframe rail??? the jacking rail????( I know someone will take that out of context, eric)
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 8, 2007
#12
  • Oct 8, 2007
  • #12
Yes ... You Know ... THE RAIL
I would have worded it more clearly but just did not know how
I was reluctant to use the word frame as we don't got one
But it kinda looks like a frame rail, it is long,and runs down each side
Just get under there and you will see it
Grady
bmac50
123
Florida
Oct 8, 2007
#13
  • Oct 8, 2007
  • #13
Grady
It's sorta like a rail, almost, kinda!
Now I get to see all these measurements after I chickend out on the LTs and ordered shorties.
Oh well I won't miss the extra five HP
One of mine already lowered about 3/4 to and inch but just for the heck of it I'll measure, it still has stock headers. The other is not lowered, has LTs and never hits speed bumps, speed tables is another story.
rj95svt
422
Hayden, AL
Oct 8, 2007
#14
  • Oct 8, 2007
  • #14
My measurements are off then. I was thinking you took the measurement from the pinch rail not the front subframe. I'll redo my measurement this afternoon.
Stanger007
2,015
Baton Rouge, LA
Oct 8, 2007
#15
  • Oct 8, 2007
  • #15
Whoops, I went from the bottom of the JACKING rail.
Wes
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 8, 2007
#16
  • Oct 8, 2007
  • #16
I took two measurements and ascertained the other
I first measured from the ground to the lowest point of the exhaust system
which was the header collector flange.
Then I measured from the ground to bottom or lowest point of that rail
at the front just before it bends at an angle and attaches to the bottom
of the floor pan.
I then use the difference to know how far the header collector flange
hangs below the lowest part of that rail.
Grady
Pokageek
2,767
MA, USA
Oct 8, 2007
#17
  • Oct 8, 2007
  • #17
Grady
So.. why don't you just make it simple and say how high it is from the ground at the lowest point...isn't that the "bottom " line?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 8, 2007
#18
  • Oct 8, 2007
  • #18
Well ... Not Really
You got everything from the ride height of my Stang which is OEM
to
A Stang that has really been slammed down in the weeds
So that would obviously mean .......
The lower the stance ... the more you are gonna drag stuff
thus
The ride height is the biggest contributor of the problem
The lowest point is not the focus of this thread
The intent of these measurements is to compare the distance
the various kinds of exhaust hangs below a common point.
In this case ... the front part of that rail thing
I press on and state the obvious
but
I strive to make it very clear
We have all seen it said "LT's hang too low and scrape on stuff"
I'm not disputing that at all.
I am wanting to get some hard data and compare
Putting the ride height aside ...
We hope to see the difference
I will say ... When I ran shortys and a Bassani cat x-pipe
They seemed to hang lower than my current Mac LT's
I scraped them a time or two on stuff
but
I've never scraped my LT's
Grady
Bosko5.0
1,067
longwood, FL
Oct 9, 2007
#19
  • Oct 9, 2007
  • #19
Thank you grady for clarifiing that. Thats what I thought you meant just wanted to make sure.
Heres my measurements:
3 3/8" from right before the collector to the ground.
5 1/2" from frame rail end to ground.
Hangs 2 1/8" lower than frame rail.
And
2 1/2" from the lowest point on the x brace to the ground.
These are BBK LT's And Steeda Sport springs.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 9, 2007
#20
  • Oct 9, 2007
  • #20
Here we have what appears to be a valid & fair comparison
My 95GT
T-5 trans
Mac LT's
4 3/8" lowest point
6 3/4" rail distance to ground
2 3/8" header hangs below rail
Bosko5.0 95GT Vert
aode trans
BBK LT's
3 3/8" lowest point
5 1/2" rail distance to ground
2 1/8" header hangs below rail
Notice the Vert frame rail is 1 1/4" lower than my GT
which
is obviously an indicator of his lower ride height
Notice the Vert lowest point is 1.0" lower than my GT
The critical measurement as I see it is ........
The Mac LT's hang 1/4" lower than the BBK LT's
One would wonder if the difference is ......
BKK's hug the floor pan tighter
or
BBK's collector flange might be a tad smaller in diameter
1/4" ... its not a make or brake a decision between them IMHO
Lets see some more that use shorty headers
Grady
1 of 2 Next Last
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
2K
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
