Header Help!!
  • Thread starter Thread starter PRO50SC
  • Start date Start date Jan 20, 2006
P
PRO50SC
1,012
Olney, Maryland
Jan 20, 2006
  • Jan 20, 2006
Got around to puttin' on my BBK equal lenght ceramic shorties on tonight. Couple of issues. Steering coupler just barely rubs the header. Anyone have a fix for this that doesn't involve removing the header? Also, there is a leak at the header to h-pipe connection, it's tight but leaks. Any fixes you all have gotten lucky with.
There were no leaks w/ my factory headers.
Thanks in advance for any help!!!
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Jan 20, 2006
  • Jan 20, 2006
For the leak you can put some silicon or something like that. That is if the silicon hold with that kind of heat.
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Jan 20, 2006
  • Jan 20, 2006
silicon wont do a thing. you might have to bend the h pipe a little bit with a prybar or something. or just unhook it and try it again. as far as the header hitting the steering coupler....just gonna have beat the header with a hammer to get it to fit. or get one of those steering shafts from maximum motorsports.
Black1987Stang
1,422
Jersey Shore
Jan 20, 2006
  • Jan 20, 2006
Mine doesnt line up if i connect it at the x pipe first then i go to install it at the header. so i have to hook it up to the header flange little loose then hook it to the x pipe then tighten them both.
P
PRO50SC
1,012
Olney, Maryland
Jan 20, 2006
  • Jan 20, 2006
Thanks, got it covered. I'm gonna' use some alignment shims from work and shim the motormounts to clear the steering shaft and try some exhaust sealer on the flange.
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
C
98 mustang keeps popping at idle like popcorn please help
  • Cannron
  • Aug 14, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 14, 2025
squeak93
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
