Yep.
In, fall 2003 I ran a best of 1.78, 13.11 @ 102.74 MPH back when my engine was stock, but had 3.73s, ud pulleys, Bored stock maf, K&N, 65mm T body, slicks, Mac equal lengths, stock H pipe [cats were not gutted] and straight pipes w/ stainless tails plus all the tweaks like timing, weight removal.. Could leave the line @ 4500 and it'd spin the slicks a bit and PULL. Car averaged high 102 MPHs all day.
This spring just passed, I went back.. added an off road X pipe, Magnaflow cat back [basically same as what I had - straight thru muff], and a ton of rear suspension work, and MSD 6AL. Ran....???? 1.77 60' 13.14 @ 102.95 MPH. Had to leave at 5200 this year to get the 1.77 60', and suspension work did its job, motor bogged so hard the car would nose over... leaving at 4500 resulted in high 1.80s
for 60s.. averaged 102.0s with the off road X pipe.
I wanted to get into the 12s on the stock motor, and I think if i'd had my ported stock headers, and stock h pipe WITH the suspension work done, it would have did it.
Others will disagree, but I think that if you have a stock engine with just bolt ons, and the stock H and cats are in good shape, then leave it, and as far as headers, I feel its worth it to remove them and hog out the messy welds inside each header primary right where they bolt up to the heads. Port them out till they are the same size as the exhaust ports on your stock heads..
For a 302 c.i. motor, These cars come with pretty decent exhaust from the factory when you stop and think [275 HP LT1s, 325 HP LS1s, 245 HP L98s etc all around 350 c.i., all had single 2 1/2" or 3" ex..]. We have a H pipe w/ balancer tube, and true 2 1/4" stainless mandrel bent dual exhaust header to tail..
I was reading in the Summit Catalogue [old one I had here] a while ago, about exhuast sizing. If I remember correct on a motor with 302 cubes 2 1/2" wasn't even needed until like, the 300 HP mark or something.
I'm just biased towards stock motor = stock H pipe and headers, [always noticed a gain with a good cat back or stock H run open at track] because I have lost too much TQ every time I went to 2 1/2" off road.. [had a 91 Calypso LX that lost a ton of TQ and had 3.08 gears too.. sold the off road stuff went back to stock..].
To quote Thumper "Just me..........".
