Header Install
  • Thread starter Thread starter superstang01
  • Start date Start date Jan 7, 2007
superstang01
448
9
29
Kingston, On, Canada
Jan 7, 2007
  • Jan 7, 2007
Hey ,
Does anyone here have any instructions of how to instal headers on a 99-04 mustang gt ,or even any pictures of the whole process . I was gonan buy them and install them with my dad but I want to no what im getting myself into first.
Thanks :SNSign:
uhoh5.0
354
Montgomery, AL
Jan 7, 2007
  • Jan 7, 2007
It is a huge PITA!!! I had a good friend friend of mine that owns a chassis shop install my headers. I went with the BBK equal length shorties, because I have my trans in and out a fair amount, although long tubes are definately the only headers worth installing because the shorties really don't give you the gains to justify the cost. If I had it to do over, (which I can't, more on that later) I would get long tubes. Anyways, this guy really knows his stuff! He installed my gears, driveshaft, control arms, pulleys, etc., etc. Anyways, he said he would install my headers for $200.00 bucks in an afternoon. Three days later, after lifting the engine off its mounts, removing the starter, A/C, and who knows what else he said he would never install a set of headers on a 4.6 again for less than $1000.00 . Seriously! He said for the time he had in it and the huge PITA it's not worth it. And really, I'm not sure that the gains would really justify the cost, unless you did do the install yourself. Just my 2 cents
M
mineralgraygt
187
nj
Jan 7, 2007
  • Jan 7, 2007
its not bad at all. i can do it myself in like 5 hours. there is a thread around here ill see if i can find or if some one else will post the link.
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Jan 7, 2007
  • Jan 7, 2007
get a few buddies, pizza & beer. Drop the K, make a saturday out of it.
superstang01
448
9
29
Jan 7, 2007
  • Jan 7, 2007
How do you go about dropping the k-member ,like what is all involved in doing that?
helty
Mar 30, 2005
1,461
Baltimore, MD
Jan 8, 2007
  • Jan 8, 2007
Get yourself a jack that will raise the car high. 2 big Jackstands for the chasis, a couple of smaller jackstands and jacks for supporting the K-member and motor.
Remove the sway bar, brake calipers, drop the struts/A-arms, take the nuts off the motor mounts, disconnect the steering shaft, and the 8 bolts that secure the K-member to the chasis. I may have missed something.
So, basically the entire front suspension and the K-member itself. I'll see if I can dig up any pics of one of the 4 times Ive done it over the summer.
superstang01
448
9
29
Jan 8, 2007
  • Jan 8, 2007
If you drop the k-member do you still have to move the motor at all ,or is it fine just the way it is??
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Jan 8, 2007
  • Jan 8, 2007
the install isnt that bad. i used the guide from fnsweet.com the motor mounts are connected to the k-member. i did the install all by myself and took about 7 hours. i still dont know how i put the k-member back up by myself. deffinitly worth it
helty
Mar 30, 2005
1,461
Baltimore, MD
Jan 8, 2007
  • Jan 8, 2007
you will want to support the motor with a jack/jackstand and some 2x4's.
superstang01
448
9
29
Jan 9, 2007
#10
  • Jan 9, 2007
  • #10
this sounds like alot of work haha ,how long does it take the average shop to do this header installation??
BCB00GT
420
Jan 9, 2007
#11
  • Jan 9, 2007
  • #11
These instructions are the best.
http://www.fnsweet.com/garage/lt_install/index.shtml
superstang01
448
9
29
Jan 9, 2007
#12
  • Jan 9, 2007
  • #12
those are great ,thanks alot man!!
LT header id
  • djj62478
  • Feb 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
General karthief
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
