I just installed my
BBK LT during thanks giving.. Me and my dad did did on the driveway (lots of pics in my site). Anyhow, we dropped the K-member and drop the engine down. For me it was a breeze.. but for my 50 yr old man.. well, he doesn't look so well. It took us 8 hours to put the driver side header on and then another 8 hours to put the x pipe and passenger side on. and another 8 hours to put the magnapack on and wrapped everything up. We did several runs to the store for tools also.
After I took it for a ride.. the moment I hit the gas on 1st gear.. i hear a tick which I found out that it's a leak. So, right at this moment, I just got the driver side header out with the K-member out again. I just fiinished cleaning all of the exhaust leak from the headers and will be installing new gasket in about 10 min or so. I will post more pics on my site
Personally, I would not spend $900 for the install. There's no way in hell. If you can rent a lift for cheap, it would be better to do it in the driveway. All and all, I learned a lot and have no problem installing new set of headers by myself
well, maybe not for the putting spring back in part. I took a couple looks at the fnsweet.com and everything was pretty much what they did except I didn't remove the front struts. Get a couple of friends and it should be a blast.
I guess I can give you the steps I took to install it since I stripped down the car 2 times in 2 weeks
I put the car on ramp and jack stands
Then remove the brace thingy
then I remove the spring and steering column arm that connected to the rotor
then I dropped K member after I got a jack under the engine
I removed both engine mounts and starter
then i remove the stock manifolds..
That's pretty much it. Enjoy..
