Header Installation
69Rcode_Mach1
1,473
Salt Lake City, Utah
Hey guys my hedman elite headers longtubes will be here soon and want to know what I will need to install those on my car ahead of time so I can prepare. The headers come with gaskets and all the bolts. I also have the torque specs. Will it be hard to fit my headers in my car? Ive heard horror stories about some 67's and 68's with 351W swaps and it freaked me out(People actually had to tilt their motors). 69 engine bay is bigger so I hope it will be easier. Will I need anything else also? Thanks in advance guys.
Max Power said:
If tilting your motor is a horror story, I am not sure you are ready for headers!!!
You took the words out of my mouth.....I was going to suggest doing that to make it easier! I would not call that a horror story, that is easy. Good luck!
Just be glad you have a Windsor!
when I had the SCJ, I did headers twice! nothing but PURE HELLLLLLLLLLL! You've got it easy, only two bolts per port, I had to deal with a big block and Four bolts per port and NO ROOM!!! It took two days, and the pass side was the easy one! You've never seen so many different socket wrenches! (Insert Sam Kennison mad yelling here)
(I still have some scars from it on my hands)
All you need to do to "tilt" the motor a bit and get the headers in is get the car up on jackstands, then loosen the two bolts that hold the engine mounts. Get a short lenght of 2 x 6 and find a suitable location to raise a engine a bit. Do one side and then the other. I would also suggest getting a set of ARP header bolts with a 5/16th head. You will find clearance real tight, and it is a lot easier to get the smaller header bolt in. You will also need to retighten those babies after a couple of heat cycles. They always come loose.
Ron
You really shouldn't have to lift/tilt the engine with a 351W. Either opt up for metal gaskets of soak yours in water first (better seal). If you have power steering, DO NOT forget the P/S slave cylinder DROP BRACKET! SHould be able to install in less than 1/2 hour.
K guys headers are here today. I was thinking of doing it today. I have to drive 30 miles to my friends house so we can use his tools and weld up the rest of the exhaust. Problem is i have work tomorrow and i don't know if we will finish it today. From the sound of it it will take 2 days. Also so i don't torque the bolts?? Do i just use a socket and try to tighten them as much as i can??
