header leak, how to check?
gnx547
283
Is there a way to check to see if the header gasket is leaking? I have a exhaust leak somewhere and I think it is one of my headers, how can I tell if it is leaking?
The black or sooty film at the the flange.
When the engine is cold, you can start the car and BEFORE it gets hot, put your hand where you think it's leaking... you will feel the leak.
^^ that's a good Idea. also throw it on some jacks stands and look for black soot around the collector flange. then start the car run you hand by the header flange quickly to feel for a leak and the same around the collector. next check the header bolts you may find some loose ones. It's also a good idea to check the header bolts from time to time they loosen up. chances are the if the header has been leaking for awhile the gasket is shot, it doesn't take long for it to get a burnt spot in it, but tighten all your bolts up and if it still leaks pop in some new gaskets.
Another way is to get a length of hose, even cut a 3' section of garden hose if you can. Hold one end up to your ear, move the other end around ALL possible places there might be a leak. Any leaks will ring through the hose loud and clear. I use this method to find exhaust leaks on any kind of car, from header gaskets to the the tip.
For an example of what it will sound like, run the end of the hose down the exhaust tip until it starts to find the exhaust. You will hear the difference right away.
