  • SN95 4.6L Mustang Tech
Header prob
  • Thread starter Thread starter war69
  • Start date Start date Apr 19, 2007
W
war69
90
Wisconsin
Apr 19, 2007
  • Apr 19, 2007
Hey guys i have a question. I have jba shorties titainium and i am now going to have to put on my 3rd gasket. im at 414hp with a kb. what gasket are u all running with blowers. i was told to go back to a ford gasket.Im talkin about the header to block gasket. Ill pay what ever price for it but i want it done right and not to leak again. any ideas will be great.
SilverBullet00
1,150
Wichita, KS
Apr 19, 2007
  • Apr 19, 2007
Get the ford stockers, they are around 100 a set but worth it!
W
war69
90
Wisconsin
Apr 20, 2007
  • Apr 20, 2007
So i know the job is time consumeing but can it be done with some common sence or leave it to the pros? Any writeups on how its done anywhere?
hotmustang331
2,967
Bastrop,TX
Apr 20, 2007
  • Apr 20, 2007
^Didnt you just say that its your 3rd gasket?
And yes its pretty simple...especially with regular exhaust. If you had a turbo it would be a darn pain...have to either prop the exhaust system up, or remove it along with all the different gaskets.
But for what your doing, just unbolt the X pipe from the headers, and then the X pipe from the catback and remove it. Then unbolt the headers and remove them...just need some a 13MM or 1/2 inch socket W/ extentions and a regular wrench Should be able to do it W/O having to jack the engine up. Time consuming, but not too hard. Just make sure you keep the gasket in good shape when putting it back on...and clean any old gasket off the heads and the header flanges.
I have Peircys seal-4-good dead soft aluminum multilayer reusable gaskets LOL...sounds crazy haha. You can get them from summitracing.com...and make sure they are for the 2V motors as they sell both ones for the 2V and 4V. I think they were like $30 each, and so far so good.
W
war69
90
Wisconsin
Apr 20, 2007
  • Apr 20, 2007
Yes i did say it was the third gasket but i didnt do the job. It has all magnaflow exhaust.I was told u have to drop the k-member to get to the headers. is this so I know im grasping but is it possible the header bolts just came loose. its only on the drivers side and not to bad right now.
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
