header problems
  • Thread starter Thread starter Brad's 70
  • Start date Start date Aug 12, 2007
Brad's 70
  • Aug 12, 2007
I have a 351 in a '70 coupe with World Products 180 heads. They are burning plug wires on drivers side. 1000 deg wires. Short plugs. Still burning. Anyone have a solution or know why? Hooker headers . looking for a solution!!!!!!
CraigMBA
783
Orange, CA
Aug 12, 2007
  • Aug 12, 2007
One one side only?
Your tune up is wrong on that one side. It could be lean (high EGT's) or rich (burning unused fuel in the exhaust) and could be caused by a wide cause of problems.
If you really want it fixed you either need to buy a wide band O2 sensor and check it yourself or you can find a dyno with a wide band and have him do it.
My buddy used to run a NASCAR late model at a track that required a muffler. The flowmaster baffle fell apart and plugged the muffler up. From the time the mufffler failed to the car starting to miss becasue we'd melted the plug wires off the thing was like four laps.
I
iapexl8r
254
Aug 12, 2007
  • Aug 12, 2007
check the color of the spark plugs. if they are white you are definatly to lean. are the headers coated??? hate to ask the obivious, but are the wires routed far enough away from the header tubes?? good luck. chris
Brad's 70
  • Aug 12, 2007
plugs r tan .. tubes of headers r touching wires . headrers r wrong or heads have moved plugs in diff location
CraigMBA
783
Orange, CA
Aug 12, 2007
  • Aug 12, 2007
Sorry, missed that part in the OP.
Yeah. You're screwed. You'll have to get new headers or change the heads.
Start calling people tomorrow.
C
chromedog
554
worlds center for speed
Aug 12, 2007
  • Aug 12, 2007
my windsor with hedman headers is really tight on the last two cylinders... i use 135 degree wires, the last two being fairly long, and turn the boots away from the header tube (i dont use short plugs) i also run heat sleeves on those two wires...
Brad's 70
  • Aug 14, 2007
hey guys, thanks. Cromedog, where'd you get those heat sleeves? Im trying to put 2 new flanges on the header to space off the head to see if it works.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
  • dan50
  • Jul 18, 2026
dan50
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
