Header temperature
  • Thread starter Thread starter BlooDReigN
  • Start date Start date Aug 3, 2004
BlooDReigN
283
Calgary, Alberta
Aug 3, 2004
  • Aug 3, 2004
I just bought a set of used long tube headers and I am thinking about painting them. We have some black paint where I work that is for painting fireplace stuff and is apparently good up to 1200 degrees. I'm wondering if this is good enough for a set of headers or should I get something better? If so, what should I get?
Thanks _
shttygtstang
978
  • Aug 3, 2004
well nomater what you use it will burn off
BlooDReigN
283
Calgary, Alberta
Aug 3, 2004
  • Aug 3, 2004
So what do you suggest? Leave them as they are or what?
shttygtstang
978
  • Aug 3, 2004
well paint um take a picture after that theres gunna b all burnt crap on your headers and it will b the last time they ever look nice.my ad vice get a wire wheel and polish them thell look good maybe not what you want but dont do that been there done that just dont
1Stang2Go
389
CT
Aug 3, 2004
  • Aug 3, 2004
have them coated.....only way to keep them nice.
Otherwise, Eastwood has header paint that works pretty well. I lasted the longest out of all the paints I've tried.
shttygtstang
978
  • Aug 3, 2004
bs it will burn off evntaly
Ray III
586
fixin Boomhower's John Deere in Troy, NY
Aug 3, 2004
  • Aug 3, 2004
That's not true. If you aren't using a half-assed high heat paint, it WILL stay on until the metal is red hot, at that point nothing will stick to it.
DupliColor HIGH HEAT paint is available at NAPA and other autoparts stores
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
  • Mindseye007
  • Aug 16, 2026
Mindseye007
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
