Header Thread Repair
vpap1
109
Have a 90 gt header bolt hole on passenger side that has stripped threads. I deff need to drill and helicoil 2 bolt holes.
Would it be enough to jack up the engine, and have enough room to drill out and repair,
Take the head off and repair or
Remove engine and trans as a unit and then repair on hoist
I am trying not to dive to far into the motor cuz when I do I have a tendency to upgrade, and money is tight
What are your opinions?
Also the heads are aluminum
Thanks
I would say pull the header out and see how much room there is to work. Of course it will depend on which bolt hole it is too, some will be easier than others to get to. You would almost certainly need to use an angle drill and probably a stubby bit to drill it out for the HeliCoil. Once that is done, the tapping and putting in the insert should be easier as those are hand operations.
Reactions: 7991LXnSHO
I'd probably remove them both maybe have them valve jobbed and have the machine shop fix the holes. Not that I couldn't fix the holes, but if I have to take one off, might as well get some power for your trouble.
Probably cost you like a total of $200.
If it were an old iron head, i'd be a fan of doing whatever it takes to fix it while on the car. An aluminum TFS head? I'd be more careful. And for the record on my old e350 351 work van, I drilled and tapped a head while on the van in a tight spot, held for about 5 years, then while doing it a second time because it was leaking again, yup, I drilled into the water jacket. JB well and a new heli coil fixed it and sold the van (told the buyer, but at $1500 you don't expect much anyway).
I still remember the sinking feeling of the antifreeze coming out.
