Headers for 351W
  • Thread starter Thread starter 67chad
  • Start date Start date Nov 9, 2006
67chad
25
  • Nov 9, 2006
I have a 289 in my 67 right now but I have been toying with the idea of swapping it out for a 357W with AFR 185 heads. My question is will my JBA 1 5/8 shorty headers fit? I know the bolt pattern is the same but every time I see someone post about swapping to a 351 they are always told they will have to change headers, why? I would like to hang on to the JBA's as they have been a good header and I also have clearance issues with my custom rack and pinion. Thanks for your help.
M
mo'factor
58
  • Nov 9, 2006
headers
The reason why most 289/302 headers will not work with the 351 is that the deck height is different and most 289/302 headers will not clear the floor support. If the crate motor you are planning on putting in is based on 289/302 your headers should fit. If the crate motor is based on the 351, then they may not fit if they are long headers. Shorties should fit for both although most 351 shorties have bigger primaries. I am running headman shorty 351 conversion headers on my '68. They fit pretty good.
67chad
25
  • Nov 9, 2006
It is a 351 based motor. what size should the primaries be for a 357 with AFR 185's I am not looking to have tuns of HP I would be happy with 400. So it sounds like shorty's are not an issue in a 351 swap right?
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Nov 9, 2006
  • Nov 9, 2006
I have a worn out 351W sitting on a stand that I'm thinking real hard about building into a nasty 393. My goal would be 500fwhp/420rwhp if I bother at all.
If you're just after 400hp, you could go either way on the header size. 1 5/8" will make more lower-rpm torque which is actually more useful on a street car(as opposed to 1 3/4"). Shorty headers are not usually an issue with Windsors. Longtubes for 289/302s have trouble being used on 351Ws because the collectors will hit the floor under the car due to the taller deck. If your shorties have at least 1 5/8" tubes, you could reuse them and just get the exhaust downtubes lengthened.
67chad
25
  • Nov 9, 2006
Thats good news. I would hate to invest another 400 in a set of headers, when I have a perfectly good set already. I would love you make more then 400 Hp but my current drive train would not hold up long I think. Thanks for all of your help.
:SNSign:
65ShelbyClone
4,675
38
119
Nov 10, 2006
  • Nov 10, 2006
I forgot to mention that shorties also free up some space for (stock) power steering and stock clutch linkages. I have longtubes on my '68/302 and the z-bar goes between some of the primaries. I have to pull the z-bar to get the header out.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
L
New here from Maine
  • lobster
  • Mar 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 5, 2026
lobster
L
1973 Headers
  • Stang_1973
  • Mar 11, 2025
1965 - 1973 Classic Mustangs -General/Talk- Apr 1, 2025
R
New heads
  • Robman8028
  • Jul 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2025
gkomo
C
Exhaust 4 Cats required for smog in California?
  • Codosuarus
  • Sep 28, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
Scottyding73
