Headers found at swap meet
Man O man. What a find. I found almost perfect set of headers for my small block for only 30$ They are ceramic coated flow tech headers which usually go for around 200$. The only thing is that there is was a leak at the point where the tubing meets the port. NO its not due to gasket leakage but defective pipe that i could fix myself with couple of spot welds or something to that extent. let me know if you guys have done this before let me know your experiences .
sounds like a decent deal, but you'll have to grind the ceramic coating off the part that needs to be welded. also if you do it yourself keep the heat low, those tubes are easy to burn through, personally i would get a good muffler shop to do it, not midas or meineke or something but a good local shop that does custom exhaust work. :nice:
