  • 1994 - 1995 Specific Tech
headers install
  • Thread starter Thread starter jshelton2006
  • Start date Start date Nov 30, 2006
J
jshelton2006
Indiana
Nov 30, 2006
  • Nov 30, 2006
i bought shorty headers for my 95 mustang gt and want to know if i can install them myself or have it done. It is a 5 speed. I just need instructions or advice on the best way to do it. I know shortys are supposed to be easier but i have heard you have to drop the k member to install some...thanks
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 30, 2006
  • Nov 30, 2006
I would not think you have to drop the k member to install shorties. The headers should have come with instructions. I would say its a do it yourself job as long as the bolts come out of the heads for you factory manifolds. If you break 1 then it becomes a little more complicated. Soak the bolts on the headers/manifolds that are on the car now in penitrating oil before you start. soak em for a day or so. repeated soakings.
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Nov 30, 2006
  • Nov 30, 2006
Do you havea decent selection of tools? Do you want to wrench on your car? For the price of someone installing headers, you may be able to pick up a decent set of tools...Christmas is coming as well, lots of sales at Sears righ now...
Off the top of my head...normal wrenches, sockets, universals and extensions will get em off. It's all personal technique how you use the aforementioned combinations to get to the bolts...don't be afraid to remove other components to get at a bolt. Defeinently do-able, even for a beginner. Pass side is easy, after removing the smog stuff and inlet ducting, driver side is a bit more challenging, I've always gotten mad at the forward bolt, PITA with the power steering pump right there.
A jack and stands, unless you have other means (lift or something) is helpful when trying to get at the joint between the headers and H-pipe
All-in-all, do it yourself!
Good luck
94Blue302GT
704
Chicago
Nov 30, 2006
  • Nov 30, 2006
not hard to do, but can be a PITA.
Some shorties you need to remove a few things to get them in there.
Are they equal lenght?
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Nov 30, 2006
  • Nov 30, 2006
Hopefully they are unequal length. They're easier to install.
Do a search in the 94-95 Tech section for "headers". You'll find some write-ups on how to do it .... and what you'll need. Definitely worth doing yourself rather than paying someone to do it.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Nov 30, 2006
  • Nov 30, 2006
Piece O Cake
compared to
Long Tubes
I would tell you to .......
Get a few hand tools
and
Gitter Done
You'll have a ball
Grady
drakesdad
961
Oregon OHIO
Nov 30, 2006
  • Nov 30, 2006
Patience......................deep breaths.....and step away if frustrated.......My BBK shorties weren't too bad....I did not take anything off of the engine......but the driver's side was the hardest.......I had to twist and turn the header to get just the right angle to get it in place.
badstang123
397
Santa Clarita, CA
Nov 30, 2006
  • Nov 30, 2006
If they are the unequal ones they're a piece of cake. As stated above the driver side will take a little twisting around but once you get it right it will slip right in. I dreaded the install for some time but was pleasantly suprised to get it done in a little over 2 hours even though I was taking my time. A helping hand from a friend would be my number one recommendation. Other than that if you have tools and a little common sense they're no problem.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Nov 30, 2006
  • Nov 30, 2006
I must have been really lucky when I did mine. Some said to take the steering arm off and a few other things. Some said not to. Well, I didn't. The driver's side ended up sliding in like a knife through butter. I guess I just turned it the right way on the first try. I think I actually spent MORE time on the passenger side.
But yeah ... I DO see why everyone has problems there. Very tight area to work.
Also, I would recommend locking header bolts .... and a Fel Pro 1415 gasket.
1TallMF
955
Montreal
Nov 30, 2006
#10
  • Nov 30, 2006
  • #10
I recall reading that the 4.6 cars need to remove the k-member and raise the engine to install headers, sounds like PITA! Yet another good reason to own a 5.0L
G
ghetto5oh
70
so cal
Dec 1, 2006
#11
  • Dec 1, 2006
  • #11
does anyone know what type and size of wrench to use? i have a nasty exhaust leak and plan to take off drivers side header to replace that gasket this weekend.
TheRedBlur
15
seattle
Dec 1, 2006
#12
  • Dec 1, 2006
  • #12
I had the bbk unequal shorty's back when they had multi-piece flanges, you had to use a prybar to bend the tubes into place because they'd warp... NOT COOL!
but yeah, step by step...
remove strut brace
remove air cleaner assy.
remove EGR assy. (rusty, use lots of penetrating oil)
remove spark plugs and wires (for ease of removal/space)
I used an 11mm wrench on my header bolts, but I don't know if that's a factory size.
remove flange bolts.
swap headers and reverse process
long tubes are a pain, you gotta jack the motor up, you keep ruining starters...
ProKiller
3,064
15
78
PA
Dec 1, 2006
#13
  • Dec 1, 2006
  • #13
right out of our FAQ....
http://www.stangnet.com/tech/shorties/shortyheader.html
J
jshelton2006
Indiana
Dec 1, 2006
#14
  • Dec 1, 2006
  • #14
OK, looks like i shouldnt have a problem doing it then. i have plenty of tools and i can get help. i hope its not too bad bc they are unequal length shorties. thanks a lot for all your help
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 1, 2006
#15
  • Dec 1, 2006
  • #15
Be sure and let us know how it goes for ya
Grady
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
