headers rubbing steering shaft
  • Thread starter Thread starter 40th Sonic GT
  • Start date Start date Oct 1, 2006
40th Sonic GT
30
louisiana
Oct 1, 2006
  • Oct 1, 2006
Ok, I got some brand new BBK equal lenth shorties for my '91 5.0. Everything went great until I cranked her up. I could hear and feel vibration coming from the floorpan. Come to find out the headers barely touch the steering shaft. Anybody ever had this problem? Advise please! Should I just send them back? If the motor was raised like a quarter inch they wouldn't touch.
Flavadave4
1,044
21
49
Utica, NY
Oct 1, 2006
  • Oct 1, 2006
Hmmmmm when i got my headers they had a dent in them to clear the shaft
Brett88lx
65
  • Oct 1, 2006
We had the same problem with my buddys MAC headers. Although his were longtubes and rubbed really bad near the steering sahft U-joint.
I would first try to bang out a tiny groove or notch. That might work. Good luck.
RYC CUKR
1,437
Orlando
Oct 1, 2006
  • Oct 1, 2006
check your motor mounts. Over time they can wear and let the engine settle some. Lots of guys have fixed the rubbing issue by replacing the mounts.
bob331T76
76
so cal
Oct 1, 2006
  • Oct 1, 2006
i had same prob... i grined down the steering shaft bolts and put a little dent in the tube to clear...no more problems
D
Deleted member 87397
Oct 1, 2006
  • Oct 1, 2006
I have the same problem with mine and my motor mounts are new. Most people just grind down the shaft a little or make a small dent in the headers as mentioned above. That's the only fix pretty much.
40th Sonic GT
30
louisiana
Oct 1, 2006
  • Oct 1, 2006
Does anybody know if they make adjustable motor mounts or kits or spacers?
joeyd0730
130
queens, ny
Oct 1, 2006
  • Oct 1, 2006
i had the same problem when i put bbk 1/58 equal length shorties in my 91gt. i had brand new motor mounts as well, i had to beat the header with a hammer, it solved the problem.. good luck
Modular2v
3,222
23
99
oklahoma
Oct 2, 2006
  • Oct 2, 2006
you could put a thick guaged washer between you motor mounts and the mounting plates
thehueypilot
1,084
Medina,Tennessee
Oct 2, 2006
#10
  • Oct 2, 2006
  • #10
You could replace your rag joint steering shaft with a newer, needle bearing u-joint type which is a lot smaller in diameter at that location.
AUBURN1111
560
20
49
Mobile, AL
Oct 2, 2006
#11
  • Oct 2, 2006
  • #11
I have the same problem BBK 1 5/8" thinking of using a spacer on the motor mounts.
40th Sonic GT
30
louisiana
Oct 3, 2006
#12
  • Oct 3, 2006
  • #12
I think I will try a metal plate spacer drilled out where the bolt goes on the motor mount or a thick washer. If this dosent work I may consider sending them back in favor of some long tubes and a short h pipe. Has anyone used BBK's long tubes? Any issues with fittment or rubbing? Thanks.
D
dlpich63
Everett Washington
May 15, 2020
#13
  • May 15, 2020
  • #13
I have long tubes and they have the same issue
General karthief
Mod Dude
Aug 25, 2016
28,118
10,736
213
polk county florida
May 15, 2020
#14
  • May 15, 2020
  • #14
This is an old thread but just for reference I have mac long tubes and I can slip a piece of paper between the steering shaft and one of the tubes, you may get a little relief by loosening the steering column under the dash and moving it, they don't move much but it may help. Or you can ding the header pipe.
nickyb
I gotta say i never painted my nuts, Never Ever
3,042
1,671
163
nevada
May 16, 2020
#15
  • May 16, 2020
  • #15
Solid motor mounts,cheapest longtubes,no issues with rubbing.besides rubbing is racing right?
Reactions: General karthief
Header clearance issues
  • BigSlappy
  • Jun 8, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2023
General karthief
Intended Headers and Trans, questions about fitment
  • from6to8
  • Aug 6, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
from6to8
Progress Thread Komo's 1990 GT - Parts Gathering Purgatory & Home Remodel
  • gkomo
  • Sep 23, 2024
  • 104 105 106
2K
89K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 2:40 PM
gkomo
Idle spark confusion
  • sav22rem22
  • Oct 26, 2023
  • Digital Self-tuning Forum
2K
Digital Self-tuning Forum Nov 1, 2023
sav22rem22
2000 GT dies once warmed up
  • bigred90gt
  • Jun 21, 2022
1996 - 2004 SN95 Mustang -General/Talk- Sep 18, 2022
My Copilot Zip
