headers rubbing steering shaft
40th Sonic GT
30
louisiana
Ok, I got some brand new BBK equal lenth shorties for my '91 5.0. Everything went great until I cranked her up. I could hear and feel vibration coming from the floorpan. Come to find out the headers barely touch the steering shaft. Anybody ever had this problem? Advise please! Should I just send them back? If the motor was raised like a quarter inch they wouldn't touch.
We had the same problem with my buddys MAC headers. Although his were longtubes and rubbed really bad near the steering sahft U-joint.
I would first try to bang out a tiny groove or notch. That might work. Good luck.
I have the same problem with mine and my motor mounts are new. Most people just grind down the shaft a little or make a small dent in the headers as mentioned above. That's the only fix pretty much.
I think I will try a metal plate spacer drilled out where the bolt goes on the motor mount or a thick washer. If this dosent work I may consider sending them back in favor of some long tubes and a short h pipe. Has anyone used BBK's long tubes? Any issues with fittment or rubbing? Thanks.
I have long tubes and they have the same issue
This is an old thread but just for reference I have mac long tubes and I can slip a piece of paper between the steering shaft and one of the tubes, you may get a little relief by loosening the steering column under the dash and moving it, they don't move much but it may help. Or you can ding the header pipe.
