Headlight/Flasher switch problem
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
When ever turn my headlights on, only the parking lights switch on. Then if I flash my brights it will work. Now I went to MU today and they said I would need a new switch(90 bucks! :notnice: and an older guy that knew his chit, told me that I would need an inline fuse, because too much power is pumped into the turn/bright switch. What I didn't ask him was, what power fuse to get, I don't want it to never go out and burn the switch again or on the contrary burn out everyother day.
This is exactly what you need. Headlight Repair Kit
The Problem is that the wiring in the car is not enough to handle the headlights and foglights and whatnot, and over time it shorts out and can cause your lights to fliker on and off and eventually just stop working completely. The fix is to repalce the switches and then run new heavier wire from the headlight switch to the multifunction(turn signal) switch.
Theres a tech article on it somewhere around here the explains it in depth.
Its also possible that the headlight switch is just bad, you'll be able to tell by pulling it out and looking at the wires that go into the plug. If the plastic plug shows signs of it being melted or burned then you are probably going to need that kit if not then just replace the switch.
Good Luck.
The bad thing about this is that Ford produced these to operate with only the fuse in the fusebox which is probably a (guessing) 20amp (????) fuse. I don't exactly understand why now after 15 years that you need to add an inline fuse.
I would agree that the entire lighting system on these cars is substandard compared to where they could be with a little thought and $50 worth of wire, solder, and patience.
I recently upgraded the entire headlight set up on my 86 to incorporate 2 relays and aftermarket h4/h1 bulbs. Now with stock sealed beam bulbs the light output is probably 50% brighter than stock on lows and 200% better on highs. And with the H4/H1 install 100% and 400% better.
I would test your multifunction switch to make sure that power is going out to the low beams before I did anything else.
I would recommend doing something to help the stock wiring and switch gear out. I chose to install relays on lows, highs and fogs and it takes a huge amount of stress off the switchgear.
Good luck.
headlight switch
Ive got the same problem as you man and was told i need a new switch well i bought a new switch from 50resto.com for 50 bucks and put it in and it still doesnt work i checked wiring fuses and everything seems to be fine so if u fix yours let me know what u did because im stuck right now.
The problem may be either the head lamp switch or the multifunction switch > aka Turn signal switch assy.Or it could be the wires just melted and came loose. All are common. I replaced my headlamp switch and it didnt fix it,so i dug deeper found drawings and I realized it was the turnsignal switch assy. easy fix.If you dont want it to go bad again rewire the fog lamps to a relay and it will stop burning out.
There is a Big Red wire with a yellow stripe that comes out of the headlamp switch If it has 12volts when you turn on the head lamp switch then you need to check the multifunction switch because the red/yellow wire goes to it before it goes to the head lamps.
Heres some diagrams to help trace wires and trouble shoot.
http://www.50tech.com/users/sljccj/lights1.jpg
http://www.50tech.com/users/sljccj/lights2.jpg
http://www.50tech.com/users/sljccj/lights3.jpg
http://www.50tech.com/users/sljccj/lights4.jpg
it could be on either end, your switch might look fine but follow the wires, i followed them and found the other side melted!
look here
