  • Mustang Sound & Shine All
Headlight questions
  • Thread starter Thread starter 85MustGT
  • Start date Start date Mar 30, 2004
85MustGT
95
Occupied San Diego
Mar 30, 2004
  • Mar 30, 2004
1. My headlights are very cloudy/foggy I tried using some steel wool but it did not help. How can I clean them up?
2. I need to adjust the headlights, one points up higher than the other. It is missing a couple of the 'tits' used to adjust them
ironheart1
131
Connecticut
Mar 31, 2004
  • Mar 31, 2004
I've been wondering the same thing actually. I've heard nail polish remover will work, and I plan to try that after it stops raining. Anyone have a good idea for this?
J
John89lx
79
Oceanside, CA
Mar 31, 2004
  • Mar 31, 2004
Wet sand with 600, 1000, and 1500 or 2000 grit sandpaper. Then polish with Mothers mag polish (white paste). They will look much better.
Milenko
Skid Mark Layer...only not fro
462
Boston, MA
Mar 31, 2004
  • Mar 31, 2004
Brass polish helps a little too. Took some of the yellow off my old lights.
C
chrisbudl1
436
springfield MO
Apr 2, 2004
  • Apr 2, 2004
the sanding works but takes forever. take your time and remove all of the yellow buildup or it will be back soon. A buffing wheel from sears did the trick on mine in about 3 mins. $10 three different wheels, and buffing compounds for different materials. good luck, I would just get new ones though.
lxsteed
1,009
Melbourne
Apr 3, 2004
  • Apr 3, 2004
All that helps, and the lights will look better, but only for a short time. You'll need to do that over and over. I'd get a new set if you could.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
2000ElectricGreen
L
SN95 headlights - where can I buy more adjustment screws?
  • lparsons42
  • Jul 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2025
lparsons42
L
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Apr 30, 2026
2005 Mustang V6
