Headlight relay location??
There is no relay, if you have replaced the switch and they still don't work you need to look for a short. The switch has a circuit breaker in it, a short will trip it immediately.
How new is the switch? It is possible it has failed even if new.
Thanks guys. I am still running the old headlights. I have always had trouble with them. If I would run them on high beams during the hot weather, they would start flickering and then they would go off. So I would always either not use high beam or make sure to have the vent open by your foot which would cool it enough to run them. Been through a few of these switches. :( Man, there is nothing I hate worse than electrical problems! :fuss: I guess I'll start looking for shorts.
I don't know what you consider your time to be worth, but tracking down a short can take forever (unless you get lucky). If it were me I'd simply replace that portion of the harness with a repro and be done with it. Then you'd have an even better sense of security, take that advice from someone who had a classic Mustang burn :(
Hehehe...you have to push the super duper ultra sectret button on the bottom to release the shaft.
Seriously :D
There's a very small button on the sheetmetal that you depress, then the knob just pulls right off.
Seriously :D
Thanks for the tips guys, I'll whoop out the secret decoder and find the secret button. Glad I didnt try and horse it out!!!!
84convertablegt said:
yeah, i tried muscleing mine out and finally gave up right before ripping it off in a fit of rage. then i got out the ford manual and read about the secret button. i felt dumb when it just fell right out after pressing the button.
:lol: Ha Ha!!!!!!! I have been there done that with the fit of rage thing!!
Bob429 That is exactly what it was!! :hail2: I unplugged the dimmer switch and checked voltage - fine. Looked like connector was corroded pretty good. Cleaned up and put some dielectric grease on - Wha la! Everything is working now. Now Just got to get my last problem of not being able to hook up fixed! :banana:
