Headlights=no Worky :(
94gtfreak
412
your moms house
SOOO.....after a few week of frustration and waiting on parts I've finally got my 93 up and running. Idle issue was dialed down to a faulty new MAF, which was replaced with a 94-95 style. Car atleast runs but not perfect. Newest issues have been lights. While taking the clear cluster off to replace with new non-cloudy piece I noticed my headlight switch harness wiring was butchered up pretty good. At the time the cars marker lights and headlights worked (both low beam and high beam) The headlights (one piece lenses) were wired wrong giving a high beam dash light constantly. Fixed that issue by rewiring the headlights and VIOLA, everything worked fine. Once dash was apart I decided to replace the harness to the headlight switch to avoid issues in the future. NOW comes the issue. Since then the headlights haven't worked. I found no power going to the red/yellow wire on my multifunction switch so I found a barely used one (MF switch) and replaced it. Now I still have no power to the headlight switch. I noticed that the plug to the multifunction switch for the headlights had a burn mark in it (in the area of the red/black plug). Now, if I hook a jumper wire from the battery straight to the wires for the MF switch harness I have headlights. Is it possible that I have 2 bad MF switches or that my headlight switch is shot?
Sorry this is jumbled, I have one eye half open. Trying to avoid spending amounts of money 'chasing' a problem if it's something easy. Any help appreciated.
I <3 boobies, :flag:, and demote/ban Brian pwease.
p.s....yes, I used the search function. No ones issues seemed the same.
Here's a diagram, sorry about the poor quality.
93-headlight-circuit-gif.71926
A word of caution about multifunction switches is in order here. The multifunction switch (high/low beam, wiper, turn signals) are different for different years. 87-98 will work in any 87-89 car. The 90-93 switches only work in 90-93 cars. You can't put an early model switch in a late model car, nor can you put a late model switch in an early car.
Supposedly you can move the pins around to make the switches work in model years that are different from the car the switch came out of. I cannot verify that and haven’t tried it.
Other possible problem sources for the turn signal & headlight malfunction are the ignition switch, multifunction switch and the plastic shell that holds the turn signal wiring connector pins.
The following diagram is for 87-89 model cars.
Turn signal switch wiring:
attachment.php
Thanks bud!!
Here's an update, car has new headlight switch connector, headlight switch, multifunction switch and headlights. STILL no headlights >:( I have power to everywhere I need it to be except at the headlight connector. All wires are good, connected, cleaned all grounds and triple checked all fuses. This car is going to be the death of me I can tell.
