Headliner
I know in a coup it does not. There is a procedure in the shop manual to do it. But I agree that you will get a better result if you pull the glass. It is also a good opportunity to replace the gaskets if there are warn before a leak gets you.
I haven't done this, but have read two articles detailing this. Or did I stay at a Holiday Inn??? :scratch:
Its the same for coupes, you can do it with the glass in place, but the best results require taking the glass out.
I did my boss302 with both glass in place, not sure if it's the same on the 67.
As I recall there were "grabbers" almost like carpet tack strip near both windows. It's a tricky job.
After doing it once myself, I'll tell you this, if the upholstry shop will do it for a reasonable fee, have them do it. It's one of those things that takes experienced feel to get just right.
Good luck with it!
