AFR205 Heads. 2.08 IN. 1.6 EX. BBC beehive springs. Set up for .600" lift Hyd. roller. $1250
TFS-R phenolic spacer 1". 2 gaskets and bolts included $25
T56 shifter. UPR Blue Thunder. Handle included. Has adjustable stops. I will include a Hurst Aluminum knob too. $100
Cartech 1/2" fuel rails for Windsor engine. $50
Aluminum driveshaft with TKO/3550HD yoke. Fits fox body and sn95. $100
Manual steering Rack. Will only fit 94-98 Mustang. Includes steering shaft and offset rack bushings. $120
50 oz flexplate SFI rated. For use with GM trans behind a 302. Also an adapter to fit a GM converter to the crank $50
SLP catback. 2 1/2". For fox LX or 94-98 GT/Cobra. Awesome shape. Stainless steel. Chrome tips. $400.
Bennett Racing Hyd Turbo cam. 242/242 @ .050" .576"/.576" lift. 114 LSA. $200
T-76 Turbo. ITS housing. .96AR turbine housing. Q trim turbine wheel. Billet back plate. Drain flange. Needs new vband assembly welded onto the hot housing. $550
Spyder EFI 90mm elbow. Powder coated charcoal gray. Will fit 4150 or 4500 carb intakes. $120
Ford Racing 4" Chrome valve covers. One has been modified slightly for clearance of the 94-95 alternator location. See pictures. Color of the letters are lt. blue. They were pin striped and can be removed. Black underneath. $75
Autometer Triple gauge pod for 94-04 Mustangs. black in color very good shape. $40
Autometer double gauge pod for 94-04 Mustangs. 2 1/16" gauges. Black in color. $20
Derale Oil cooler with fan. 12x10" -6 AN male fittings. it has 3/8" barb fittings included. $75
Full set of Ford Hydralic Lifters with retainers (will work in Dart blocks) $50
