Grits SEE!! I do have a neck! Founding Member Aug 25, 2000 2,013 0 46 Colorado Springs, CO Aug 2, 2006 #1 Aug 2, 2006 #1 Got my heads back from the machine shop today and they were taken down .007 from stock (Gt-40p') Can i still use the stock length pushrods? or should i go alittle shorter?
Roland69 Sergeant Tangnet Sep 17, 2005 2,867 3 58 Port Elgin, Ontario Aug 2, 2006 #2 Aug 2, 2006 #2 I believe you can use your pushrod's but you might need to adjust your valves
donsbad68 Immensely Educated Jan 4, 2003 838 0 0 Oklahoma Aug 3, 2006 #3 Aug 3, 2006 #3 hit the pedestal seat on the head with a touch of 200 grit sandpaper then roll with it. I doubt you will have an issue.
STANGateURlilSS Founding Member May 2, 2002 716 0 16 USA & SANDBOX Aug 3, 2006 #4 Aug 3, 2006 #4 get a push rod length checker and check the length of the pushrods..
