Heads
  • Thread starter Thread starter morstang05
  • Start date Start date Jan 24, 2011
M
morstang05
33
  • Jan 24, 2011
Are porting the stock cylinder heads worth the money as far that the hp increase?
BluDevil
12
MO
Jan 24, 2011
  • Jan 24, 2011
It depends alot on the application, if you plan on putting a power adder on, then the heads will pick up some good numbers. For n/a I think you get around 30hp or so, I could be wrong but seems like its around there. If you are going to do heads I would suggest doing cams as well. One thing to keep in mind when doing heads is to be true to what you are going to be using them for. If your going to keep the stock bottom end and no power adder dont get the biggest flowing head numbers because they wont be as good as a smaller port job because you will lose air velocity. I was quoted around 4000 for a head port and cams from a local speed shop I deal with. Hope this helps.
M
morstang05
33
  • Jan 24, 2011
Thanks for the info. I was planning on doing SC, but had a change of heart. Going to keep n/a. I know with porting the heads, gains of around 25-35 are possible, but what about doing the cam and new valve springs? what kinda power would it bring?
I want to make 400hp with n/a motor
BluDevil
12
MO
Jan 24, 2011
  • Jan 24, 2011
Ya I agree with you on the change of heart, just made the same decision myself. Sadly if you want 400 hp to the tire your most likely going to have to stroke the engine. I have been checking out the FRPP BOSS Modular block for my build when the warrenty goes out, they say you can bore and stroke it out to a 336 which I think comes out to a 5.4 or so. The shop that I spoke with said I would see about a 60hp increase with the heads and cams. Comp cams claims you will get more hp with the spings and phaser mods, Personally I would do them since you will be in their anyways with the cams, but that will also increase labor costs. I believe Brenspeed sells a n/a cam with good #s without changing the springs or phasermods if you decide to go that route. Livernois and FRPP sell some nice sets of cnc heads if you havent looked at them yet.
SpartaPerformance
2,517
61
89
Long Island NY
Jan 25, 2011
  • Jan 25, 2011
Porting stock heads isn't worth it, too much down time. You can get already CNC'ed heads from Ford Racing or Livernois. A custom grind set of cams specific to your application with the porting will net a nice amount of power. I was going to go the same route but your going to spend 75% of a supercharger and only 60% of the power gains.
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
M
What cam and heads should I run in my stock 302.
  • MadMatt7
  • Oct 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2026
FastDriver
O
Timing guide
  • oilleak1000
  • Oct 10, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 10, 2026
oilleak1000
O
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
