heater/air control panel stuck in defrost
By defrost, do you mean the air only blows thru the defrost vents? If so, then look for a vacuum line break or disconnect under the hood near the firewall. I had the same issue that was corrected by fixing a break in one of the lines going to a vacumm tree.
