  • 1994 - 1995 Specific Tech
Heater Problems????
  • Thread starter Thread starter Sompin2do
  • Start date Start date Dec 8, 2005
Sompin2do
59
TX
Dec 8, 2005
  • Dec 8, 2005
I've searched on this topic and am not sure about a possible solution.
I'm looking at a 95 Cobra to purchase and am concerned because the heater does not blow hot at all. The guy has only owned the car for 1 year and has never had it looked at. It has low miles 77,000 and has been well taken care of. He needs a truck for a start up business so I don't suspect abuse.
Is there an easy way for me to diagnose if it could be the thermostat? Water pump? Other? Last resort will be for me to take it in and pay to have it checked just in case.
Thanks for the help
Mike
CManT1914
3,172
Killeen, Texas
Dec 8, 2005
  • Dec 8, 2005
Probably the heater core. That's a pretty tough job there. Although a blazer came into the dealership yesterday with a leaky heater core, one of the other guys had it out and the new one in in just a few hours.
Sompin2do
59
TX
Dec 8, 2005
  • Dec 8, 2005
Oh man, that makes my head hurt. I did it on my 90 GT and hated every step, except of course the money saved in labor. :>
If it were the heater core, wouldn't there be an odor from antifreeze? There are no signs of leaks or smells inside.
CManT1914
3,172
Killeen, Texas
Dec 8, 2005
  • Dec 8, 2005
Oh yea, I forgot about that. I don't remember if the blazer smelled or not, I didn't do that job. If it's not the heater core, then I'm not sure what it could be (completely brain dead right now, sorry).
Sompin2do
59
TX
Dec 8, 2005
  • Dec 8, 2005
Thanks for your suggestions. I may have to take it in before I decide on buying. I've done zero work on the 94s and up, and don't want to start with the heater core.
a50sn95
368
Elk Grove, CA
Dec 9, 2005
  • Dec 9, 2005
It's not likely the Thermostat or the water pump. Does the temp guage seem to get to the normal range?
It COULD be the door in the HVAC system not opening. Maybe a vacuum hose disconnected.
Look to see if the heater core is bypassed. Check the hoses into the firewall. If the core has failed, this is an easy way to make the car driveable. If the core was leaking and not bypassed, you'd be dumping water/antifreeze on the carpet.
My guess is either the door isn't opening, or the core is bypassed.
I did my heater core a couple of years ago. It's a big job, but it's NOT hard. Basically lowered the steering column, and pulled the dash out far enough to get the top of the hvac box pried up to get the core out. Took about 8 hours, but I took my time...
Sompin2do
59
TX
Dec 9, 2005
  • Dec 9, 2005
The good news is the seller had the heater problem checked out. The bad news is the prevoius owner bypassed the core......
Can anyone recommend a really good manual to use? Good step by step instuctions? I've got a good book for the 90-93 but not a 95.
Am I crazy for considering doing this myself? Thanks again for the feedback.
Man I wish I lived near my old Air Force buddies! We used to tear into each others cars all the time!
a50sn95
368
Elk Grove, CA
Dec 9, 2005
  • Dec 9, 2005
Probably as close as you are going to get. Remember to disconnect the battery and wait a while so the airbags don't go off...
This is exactly how I did mine....
How-To
a50sn95
368
Elk Grove, CA
Dec 9, 2005
  • Dec 9, 2005
Just set aside enough time, get a GENUINE FORD heater core, and take your time. It's not hard, and an easy way to save yourself about 800 bucks. Use it as a bargaining tool to get the price lower, or for him to pay for it.......
Dennis
Sompin2do
59
TX
Dec 9, 2005
#10
  • Dec 9, 2005
  • #10
Thanks Dennis. How similar is this to the R&R for a 95?
a50sn95
368
Elk Grove, CA
Dec 9, 2005
#11
  • Dec 9, 2005
  • #11
Very similar. I used website that showed a FOX how-to when I did mine...
Seems like I had a couple of dash screws to find, but no big deal. I even left my A/C in like this article shows....
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
rebuilt heater box, weak heat
  • connella08
  • Jan 10, 2023
2K
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2023
