Heating a large garage
  • Thread starter Thread starter millhouse
  • Start date Start date Nov 10, 2006
millhouse
1,985
Simpsonville, SC
Nov 10, 2006
  • Nov 10, 2006
Well...it appears the house I've been trying to buy is going through. It needs some TLC and interior work...but the garage was built in 98 and is 37X29 with ~ 11-12 foot ceilings. The walls are insulated...but I'll have throw something on the back of the garage door.
Now...if I close before the end of november, I'll have some extra loot to throw into home improvement. The first thing that comes to mind is a heater for the garage...possibly one that can heat it throught the winter. I'd like to keep the price at or around $500.
Now...Ideally I'd pick up a infrared overhead gas unit and be done with it. Unfortunatly, there is no gas run out to it currently...and I'm not sure if I'll be able to lay the pipe before the ground freezes.
I've been eyeballing a 3200watt electric quartz overhead unit...but am unsure if one will be sufficient to heat the garage. There is no way I'll run two of em though.
I'm somewhat sold on a radiant heat system...as I've heard they do a much better job keeping it comfotable at all levels. Seeing as I would like to heat it throughout the winter...I see it as a better/cheaper heating solution when compared to forced air.
I'm not completly sold though...so ny and all input/opinions would be appreciated
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Nov 10, 2006
  • Nov 10, 2006
well are you talking an actual unit.. or one of those portable styles.. my pa has a readyheater.. it heats up the garage in about 5 mins.. all you need is an extension cord and a can of keroseen (sp?).. sucker can burn your face off though lol
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Nov 10, 2006
  • Nov 10, 2006
are we talking about keeping the garage heated at ALL times???
If your garage is very large at all its gonna be expensive.
Ours is a 3 car detached garage and we heat it with a small propane heater... but ONLY when we know we will using it for more than an hour.. because its expensive to keep heated.
Also. make sure the whole place is insulated well and there are no leaks.. that will make a HUGE difference in keeping it heated..
TrophyHead
1,195
11
49
PA
Nov 10, 2006
  • Nov 10, 2006
Radiant heat is your best bet mark my words. Get an indirect hot water heater or On-demand hot water heater. Research those two heaters.
89 Saleen#455
519
New England
Nov 10, 2006
  • Nov 10, 2006
This topic came up last week as well. See attached thread.
http://forums.stangnet.com/showthread.php?t=668441
I went with a 40K BTU forced hot water set-up and could not be happier. Electric heat is very expensive.
A lot depends on what type of temp. you want to maintain in the garage. I usually leave my thermostat set at 40 degrees which requires very little heat to maintain. I bump it to 52 if I'm going to be working in the garage and it only takes about 10 mins to reach full temp. It's a very efficient set-up.
N
niklid05
140
Kutztown PA 19530
Nov 10, 2006
  • Nov 10, 2006
http://www.econoheat.com/heaters.htm
if you can get ahold of used oil very easily. Just advertise that you get rid of used oil. My dad has one in in 40X20 garage and it warms it up VERY nicely. You can wear a t-shirt and shorts in there when its -10 out, and his garage door and sliding door isnt insulated. Everything else is though.
BadAndy
766
Ohio
Nov 11, 2006
  • Nov 11, 2006
how much oil will it use in like 4 hrs??? and what did it cost???
N
niklid05
140
Kutztown PA 19530
Nov 11, 2006
  • Nov 11, 2006
honestly I couldnt tell you. I know he has a house oil tank which I believe holds 250 gallons. Im guessing a couple gallons a day.
My brother runs an oil change place and he has one there too. My dad gets oil from him and from his buddy who is a heavy machinary mechanic.
millhouse
1,985
Simpsonville, SC
Nov 11, 2006
  • Nov 11, 2006
Well...I dont want a temporary heating solution, so I'm not looking for anything portable.
Ponypower89, yes...If I can find an effeciant enough solution...then I'll heat it year round. The garage is fully insulated with the exception of the door...but I can always add some insulation to the backside for relatively cheap. As far as the temp goes...I'd be looking for a constant 50F+, depending on costs.
89sallen, I saw that thread earlier...but none had a garage bigger than a 2 really. Most only had a 1 and the heating meathods seemed smallscale and innefeciant for a larger area. Now, I hadnt researched the hot water methods...although I'm not to keen on digging down to run a line. Still though...it's an option I'll look into, thanks!
I'll be using the garage to work on the stang....and I have a lot of work to do, let me tell ya. I'll also be using it for parking of my winter beater (I hate scraping windshields).
Now...Forced air units seem great to quickly heat the garage...but once the garage door opens say goodbye to the heat. They dont seem to be an option with fulltime heat. They also only heat the air. It seems that your tools will stay freezing cold...and can possibly rust from the condesation from the rapid heating/cooling of the air.
Another issue is heating the concrete. With forced air units, the concrete and your feet stay cold. Heaven forbid you have to lay on the ground to do any wrenching.
So...for now it looks like I'm heavily leaning towards radiant (unless someone knows another method or has experience showing otherwise).
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Nov 11, 2006
#10
  • Nov 11, 2006
  • #10
i seen you post on turbomustangs..... my garage is a 2.5 car garage with open rafters and no insulation plus the garage is 30 years old. my 80 000 btu propane heater works awsome at -30C. unless you runt he heater all the time the tools will stay cold and the floor will still be cool. even with permenant heat the floor will be cool.
keeping warm up here is something we do well
millhouse
1,985
Simpsonville, SC
Nov 11, 2006
#11
  • Nov 11, 2006
  • #11
The idea behind the overhead radiant heater is that it doesnt heat the air...but rather the concrete slab and all solid objects within the room. They in turn radiate heat throughout the air. Once the concrete and all objects heat up, they stay warm for hours (assuming good insulation). The Heater would only come on to maintain the temperature of the concrete slab...and other solid materials.
After looking briefly at the above head gas units...they seem to be a bit more expensive than what I had origianlly thought. http://www.northerntool.com/webapp/...?storeId=6970&productId=200316369&R=200316369
88_GT_5_oh
Jul 4, 2004
WPG/MB/CA
Nov 11, 2006
#12
  • Nov 11, 2006
  • #12
yes if you run it all the time. i prefer to run mine only when needed, it only costs me $20 to fill a tank of propane and it lasts me a good 2 weeks
WTB/Trade Looking for a T-Top Hatch. Possible convertible trade? (Rhode Island)
  • 7upper
  • Mar 18, 2025
Fox Body Mustangs For Sale (1979-93) Mar 18, 2025
7upper
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
D
Double check my electrical diagnosis of light issues on 65 Coupe
  • Duke City Novice
  • Jan 21, 2024
1965 - 1973 Classic Mustangs -General/Talk- Feb 4, 2024
AeroCoupe
