  • 2.3L (N/A & Turbo) Tech
Heavy hesitation during Acceleration
  • Thread starter Thread starter shlby123
  • Start date Start date Dec 5, 2007
shlby123
579
Dallas
Dec 5, 2007
  • Dec 5, 2007
Hey fellas. I have a '93 2.3 Convertible that I just picked (trying to save from parting out if possible) and amongst the money things on that need some work are the idle and acceleration issues it has. When I'm at stoplights the tach suck downwar FAST to right around 300-400 RPM and just baaaarely stays running, but hasnt ever just died on me yet. (Car is a 5 speed) And when I try to accelerate in any gear I get heavy hesitation border-lining chugging as I try to move. The only time it does not happen is when Im doing 60-70 on the highway and then it's great. Anybody have a list of all the different things I should check/replace? please.
Distortion 5.0
114
  • Dec 5, 2007
I would do a complete inspection of the ignition components. Check timing, and maybe even inspect the timing belt for wear. I would look out for vacuum leaks too. Those can make MAF car's run screwy. Then you could test fuel pressure, compression, maybe even do a fuel injector balance test.
shlby123
579
Dallas
Dec 5, 2007
  • Dec 5, 2007
how do I do a fuel injector balance test? Is that strictly for a shop?
Distortion 5.0
114
  • Dec 5, 2007
Depends on your ability. It requires a tool that connects to the injector, and a fuel pressure gauge. What you do is prime the fuel system, then use the balance tester to pulse each injector, and then measure the fuel pressure drop on each injector. Best way is to prime the system per injector to make sure you get accurate readings.
I haven't found a cheap balance tester yet, I've been thinking about just making one. If I get around to it and it works good I'll post a DYI write up. I don't think they are all that expensive, but nor are they complicated.
*EDIT*, oh, and check the codes if you haven't yet
shlby123
579
Dallas
Dec 5, 2007
  • Dec 5, 2007
cool I'll pull some codes and post back up. The best starting place anywho I guess
SILENTCARL
40
  • Dec 11, 2007
It really sounds like an ignition problem. Maybe the Ignition Module?
Distortion 5.0
114
  • Dec 11, 2007
He would have a DIS module. And usually when those go out the tach starts reading 50% less than actual engine RPM right? It's been awhile since I trouble shot a 2.3 but I believe that's what mine did.
I have two DIS modules I need to find homes for if anyone needs one. PM anytime.
J
89 2.3 LX running rich, hesitation on acceleration, high and hanging idle Help!
  • jpstucky
  • Jun 13, 2023
3K
2.3L (N/A & Turbo) Tech Jun 15, 2023
jpstucky
J
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
6K
Other Auto Tech Jul 28, 2024
manicmechanic007
The Death of a Cobra II
  • 76_Cobraii_mustang
  • Oct 2, 2023
3K
1974 - 1978 Mustang II Talk & Tech Oct 3, 2023
2Blue2
J
Please help!!!
  • JiggaHawkin
  • Sep 26, 2020
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2020
JiggaHawkin
J
Possible ignition problem ( very hesitant weak motor )
  • BlazeAtwood10
  • Mar 14, 2021
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Mar 17, 2021
BlazeAtwood10
