Hello all
  • Thread starter Thread starter Razor_one_seven
  • Start date Start date Aug 27, 2018
R
Razor_one_seven
Fairfield ohio
Aug 27, 2018
  • Aug 27, 2018
So I've recently bought a 95 mustang starts and runs like a champ but no brake pressure
Upon attempt to bleed the calipers after replacing brake hoses (caliper to brake line) I noticed about 5 puddles of fresh brake fluid on the ground
What am I in for in terms of changing out my brake lines I'm short on cash and can't afford the shop quote at 6-8 hundred dollars
And also can anyone point me in the direction of a brake line kit
Thanks
hoopty5.0
mechanicus terribilis
7,834
6,983
214
SW Houston
Aug 27, 2018
  • Aug 27, 2018
Those cars are very abundant in junkyards. If your hard lines are indeed trash, you could get some there for cheap.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 27, 2018
  • Aug 27, 2018
Crawl under the car or have it put up on a lift. Start looking for rust and if you find rusty brake lines, the car was probably driven in an area that salted the roads in winter. Then start looking for rust in the front shock strut towers...
Reactions: Davedacarpainter
billison
I like tinted tail
2,607
1,094
184
stl
Aug 27, 2018
  • Aug 27, 2018
Get under it and find the leaks.
Get a cutter and flairing tool. Cut a few inches in front and behind the leak and then replace with fresh line.
Or https://lmr.com/products/94-04-Mustang-Brake-Lines
D
Dan83
N.E. Ohio
Aug 29, 2018
  • Aug 29, 2018
Get your car safely up, check to where the leaks are. You can buy brake lines at the parts store. Rent a brake line double flare tool and pick up a small tubing bender and tubing cutter, then make your own. If you mess it up, try again. No way would I pay some shop 6-8 hundred bucks to repair my brake lines.
Reactions: Razor_one_seven
R
Razor_one_seven
Fairfield ohio
Sep 10, 2018
  • Sep 10, 2018
Exactly my point and that's on the low end they want 900+ if I have abs speaking of which where would I find my abs system and any ideas on material to use for the lines themselves in using double wall steel and it doesn't really wanna come out right when flaring
R
Razor_one_seven
Fairfield ohio
Sep 10, 2018
  • Sep 10, 2018
Also trying to stay away from junkyard cars I'm in Ohio so the rusted brake line issue is very common on the stock lines
R
Razor_one_seven
Fairfield ohio
Sep 10, 2018
  • Sep 10, 2018
One last thing the car was bought brand new and the owner had the car done with all the gt accessories except for the engine and transmission would it be possible to do a gt brake line kit since that would be in my budget without the headache if not what are the differences between the gt and v6 brake lines (been looking for awhile and can't seem to find an answer)
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,085
224
Massachusetts
Sep 10, 2018
  • Sep 10, 2018
Brakes are the same between GT and V6 in 1995. The bigger differences are between ABS and non-ABS.
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Sep 10, 2018
#10
  • Sep 10, 2018
  • #10
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 10, 2018
#11
  • Sep 10, 2018
  • #11
dude, go on craiglist, the Corral, or Ebay and you will find dozens of guys parting these cars out. So does MPS, Out to Pasture Pony Parts, and Matt Heimer in South Florida.
R
Razor_one_seven
Fairfield ohio
Sep 10, 2018
#12
  • Sep 10, 2018
  • #12
Worth a shot thanks
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
  • dan50
  • Jul 18, 2026
dan50
