Help! 1988 Ford Mustang 5.0
Ira
I have a 1988 Mustang 4 Cylinder converted to a 5.0. It will run but won't crank. When you turn the key switch to engage the starter the engine will run but when you left off of the key switch it will die. It has all of the 4 cylinder original wiring and everything is hooked up to the distributor and to the coil from the 4 cylinder wiring, it does have the 4 cylinder computer.
The things that I have tried:
I put a new key switch in, and put a new ignition switch. I've put extra grounds on it and I've checked all grounds going to the starter and other places, everything seems to be fine. I've also changed the wiring and wired it straight from the battery to the coil to the distributor and it will not run at all.
Need help on getting this to crank.
Also, I have changed it from fuel injection to a carburetor.
I am running electric fuel pump With a regulator to 6# for the carb.
Solenoid switch side towards the battery tray I only have the starter wire.
all others are on the other side.
1-wire is top center.
Another note: The car will run. I can start the car; while the starter is engaged pull the top wire off the solenoid switch. The starter will disengage but I have to hold the key switch as if I'm trying to crank it. let it loose it will cut off.
Thx
Ira
With the change to carb, you are on your own. If it was EFI I could tell you exactly where to look. A carb conversion can be done many different ways, and most of them are wrong somewhere. You created your own electrical nightmare and will need someone with electrical smarts present at the car to fix what has been done.
If you are using the computer for anything at all, that is a clue to a conversion done incorrectly.
A word of warning on EFI to carb swaps: don’t expect to pass emissions in any state that does comprehensive smog inspections, because it won’t happen. Some states will not title or issue license plates to cars that have been converted from EFI to carb. Be aware that you are violating several Federal laws concerning the removal of pollution control equipment. If you operate the vehicle on public highways and get caught by state or federal law enforcement (doubtful, but possible) you could be subject to fines and imprisonment. You won't get any more power from a carb than you will from EFI.
The following information is intended for informational purposes only. Operation of a motor vehicle modified in such as manner as described below should be limited to off road use only.
Doing the swap: You must know how to read electrical diagrams and wire circuits properly to do the swap. Don’t take shortcuts or cut corners in the fabrication of the electrical or mechanical assemblies. If you do NASCAR quality work, the car will look good, run good and be as reliable as a carb’d car can be. Take pride in a job done with excellence.
If you are one of those few people who do excellent work, please disregard my negative comments. They are not intended for you.
Quality, quality, quality…
Some of the motivation of my negative comments about carb to EFI has to do with the quality of electrical workmanship. A lot of the wiring “repairs” that I have seen on the road and in the junkyard looks like road kill. The other part of my negative view stems from people who can’t grasp the operation and tuning of EFI. Carbs have their own set of requirements and some learning is required to get the best performance. Every car is different and each installation needs to be tuned to get the best performance. Putting an “out of the box carb” or one from someone else’s car isn’t the way to success. There is no auto compensation for small variations in carbs like there is for EFI. Just throwing a carb on a car because you won’t bother to learn how EFI works is a poor excuse.
Now that the rant is over, here’s some practical advice…
1. Do not use an EFI in tank fuel pump with a carb. You will never get the pressure/flow regulated properly. If the add on pressure regulator fails, you will flood the engine with gas and wash all the oil off the cylinder walls. That will cost you big time $$$. Either go full EFI or use a tank/fuel pump/fuel lines out of an 84 or earlier Stang. Fabricating your own setup is possible but there are some snags to overcome.
2. Do not attempt to leave the EFI computer in place in an attempt to control either the electric fuel pump or ignition. Doing so qualifies you for the “Road Kill Mechanics Award”.
3. If you try to use your current tank, you will need to pull the fuel pump out and fabricate a pickup tube & strainer sock to replace the fuel pump. Or you can have a sump fabricated and welded onto you existing tank. Many welding shops will not weld fuel tanks because of the dangers involved if the tank isn't purged properly.
4. You will need an external electric fuel pump unless you change the timing cover for one with the mechanical fuel pump mount on it. Rip all the EFI wiring out, and the computer controlled fuel pump won't work. You will need to add a relay & switch and wire in the existing inertia switch for an external low pressure electric fuel pump. Do not try to wire the fuel pump without the relay. The 15-20 amps the pump pulls will overload the circuit. This will take power away from other items on the same circuit or cause the fuse or fuse link to blow.
5.
fuel-pump-relay-for-carbd-cars-gif.50041
6. You will need to run some new fuel feed lines or braided hose. The 3/8" aluminum tubing works well, but you will need a flaring tool and bending springs to fabricate the lines. Braided hose is easy to run and route, but is much more expensive. It is about $3.50-$4.00 a foot plus the end fittings, which are $3-$4 each. Fabricating hose assembles can be difficult, but anyplace that makes hydraulic hoses can do it for you for an extra charge. See http://www.amazonhose.com for more information.
7. For some help fabricating your own stainless steel hose assemblies, see
8. http://www.turbinefun.com/Stainless_Braided_Hose_Assembly.asp
9. For stainless steel braided hose and fittings for automotive use:
10. See http://www.summitracing.com/search/?keyword=stainless steel hose&dds=1
11. http://www.summitracing.com/search/?keyword=stainless steel hose&dds=1
12. http://www.jegs.com/webapp/wcs/stor...hall&searchTerm=stainless+steel+hose&x=18&y=4
13. See http://www.eaton.com/Eaton/Product...rformanceProducts/FittingsProducts/index.htm for more information on High performance automotive hose products
14. AN fittings require a 37 degree flaring tool. A standard automotive or household plumbing tool is 45 degrees and cannot be used with AN flare fittings. If you do, the flare is subjected to too much stress when the fitting is tightened, and is likely to fail or leak.
15. See http://www.mscdirect.com/ , http://www.mcmaster.com/ or for the flaring tool you will need . Prices start at $85 and go up
16. http://www1.mscdirect.com/CGI/N2DRVSH?PACACHE=000000013509163
17.
18. http://www.mcmaster.com/#flaring-tools/=b4fxc3
19.
20. Last time I was in Summit racing, they had a 37 degree flaring tool for less than $40. It may or may not be a catalog item.
21. While you are at the electrical part, you'll need a Duraspark or similar ignition system. The 85 Mustang GT 5 speed has a suitable Duraspark distributor with a steel gear compatible with the roller camshaft. The EFI ignition depends on the EFI sensors to advance the spark. Rip out the TPS and MAP/Baro sensors and the computer will have no idea of the proper ignition timing for best performance. Running a fixed timing setting is only for test purposes or for a race track only car. Don't try it on the street: the results will not be nearly as good as a properly setup Duraspark or equal. Crane makes a really nice distributor for non-EFI applications. . See http://www.cranecams.com/index.php?show=browseParts&lvl=4&prt=127 for more information. Cost is about $400, which makes the 85 Mustang reman units look really appealing.
Duraspark II ignition diagram:
Diagram courtesy of /www.billwrigley.com
See http://webpages.charter.net/1bad6t/duraspark.html for more help.
22. Tools needed:
23. Crimp tool for connector pins $9-$30 AutoZone, NAPA, Advance Auto Parts or other store
24. 100-150 watt soldering gun (recommend WELLER 8200PK soldering gun kit 100/140W) $30 at Lowes or $40 at Home Depot
25. 3/32”-1/8” rosin core electrical solder, 1/4 lb roll $6 at Ace Hardware, Home Depot or Lowes
26. Assorted sizes of heat shrink tubing. Buy long pieces and cut length to fit. It is cheaper that way. http://www.partsexpress.com/webpage.cfm?&WebPage_ID=346&CFID=169547&CFTOKEN=34300345
27. Hot air gun to shrink the tubing ($30-$40) Home Depot
28. Jeweler’s screwdriver kit $5 at Ace Hardware
29. Assorted automotive wire, 18-16 gauge 10’-20’ foot spools in different colors. $5 a roll at Advance Auto Parts.
30. Ford connector pins AutoZone, NAPA or other store $5-$10 for a kit of 10-12 assorted pins
31. You will have $110-$150 in materials and tools if you don't already have them.
32. The water temp and oil pressure signals feed from the sender to the main harness through the 10 pin EFI engine harness. To utilize these senders, you need to identify the wires and find a way to reconnect them to the main harness after the EFI engine harness is removed. You need a weatherproof quick connector to join the sender wiring to the main harness.
33. See the graphic for the 10 pin connector circuit layout.
34.
salt-pepper-10-pin-connectors-65-jpg.68512
35. The injector power pin is the VPWR pin in the black 10 pin connector.
36. You will need to construct a wiring harness from the ‘85 carb distributor to the Duraspark box if you go Duraspark, or other distributor to coil wiring.
37. The voltmeter picks up its signal from the switched voltage present on the instrument panel, so you don’t need to worry about that.
38. The fuel tank gauge is also independent of the computer wiring.
39. AutoZone wiring diagrams can be found if you are willing to dig through the self help repair section of their website. http://www.autozone.com/autozone/re...3835D6CFF5E3A5037BBBD332CF445FF.diyprod2-b2c3
40. How to solder like a pro - http://fordfuelinjection.com/?p=7 a must read for any automotive wiring job.
41. Soldering pigtails onto existing pins is road kill quality work as far as I am concerned. Take some time to study the way the Ford connectors are assembled and you will find that a small jeweler’s screwdriver will release the pins from the connector shell. New pins and a crimping tool are available from the Standard Motor Parts or Bendix Electrical parts line that the NAPA & Bumper to Bumper Auto Parts stores carry. Ask any auto parts store about Standard Motor Products or Bendix Electrical wiring parts. Those that carry them will be able to get the parts you need. AutoZone has a cheap kit with 10 pins for about $5. Just enough pins to leave you short when assembling a connector.
42. One of the interesting things about the Ford OEM wiring diagrams is that the connector shape on the drawing matches the connector shape in the car. That makes it easier to identify connectors and circuits. OEM Ford diagrams are available at for an 85 Mustang at http://www.helminc.com/helm/Result....edia=&mscsid=2M838NG3R5SR2MCS00A3HVE05T03C501 or can be found in the Chilton series of auto repair manuals for Mustangs.
43. The following is an excellent idea from a fellow Stangnetter who tackled the wiring plan the right way. He obtained the wiring diagrams from an 85 carb'd V8 Mustang and laid them out side by side with the diagrams from his car. He then traced out each circuit and the wire colors and connectors associated with them. After tracing the circuit and connectors for a circuit, he laid out the changes he needed to make. One circuit at a time made a difficult big job into many smaller easy to manage jobs.
44. Copied from pikapp33
45. I recently changed my EFI mustang back to carb with MSD ignition, to save some money and go for a more simplistic approach. I researched, and found the best stock type distributor to use was from an 83 Bronco 5.0, which is a Duraspark (magnetic pickup, same as what MSD dists use), making it possible to use the 2 wire MSD trigger input, and also has a steel gear to work with the EFI hyd roller cam.
I chose to use a Richporter FD30 ($85). Then added a BWD C194A Cap Adapter ($12) to use the Fox style dist cap/wires (the Richporter comes with cap/rotor, which I didn't use; other brands come without and are cheaper, but have a core as well; no core on this one). And then a BWD D166 rotor ($6) to match the cap adapter. I also chose to buy the MSD 8869 adapter wire ($20ish) to connect the dist to the MSD harness for my 6AL. All together about $125, much cheaper than the MSD billet dists, and am very happy with the quality of the the dist and the way the setup worked out.
46. The Richporter FD30 distributor is available at Advance Auto Parts ($90) & O’Riley’s ($81)
The 4 cylinder computer is hooked up. I was hoping to keep these parts so everything else will work. The only change was I had to make the distributor hook up longer. I just plugged everything up. I was hoping someone could tell what wire needs to be changed or an extra hot wire ran where. I have read where this set up will work. & I have seen 1- car at a car show running with the 4 cylinder wiring but I don't know how they did it. You would think with a carburetor set up it should work.
Thx
Ira
Might be easier to run one of those all in one distributors . Where it has a power wire and a wire for the tach. I did this when I got rid of the CFi on my 85 auto. Very easy, worked well.
If you are going to do a carb conversion, do it right. The instructions in my previous post tell you what you need to do.
The quality of workmanship is up to you: do it wrong and the trashy little Honda the next street up from you will blow your doors in with no problem. If you don't have the technical skills or the money to do a good job, sell it as is on Craig's List and keep the roads safer for the rest of us.
As far as converting a 4 cylinder to a 5.0 , the body shell is just about the only thing that is the same. The brakes are different, the suspension is different, the rear axle is different, The electrical system and wiring are different. The fuel system is different. There are so many different parts, that the only practical way to do it is to have a rolling 5.0 chassis to rob parts from parked next to your conversion chassis.
See http://forums.stangnet.com/showthread.php?t=516785 for help on how to do a 4 cylinder to a 5.0 conversion.
The 4 cylinder computer is scrap, sell it on eBay. Trying to use it is like breeding a buffalo with a gorilla: It just isn't going to happen. All you are going to have is a big, ugly hairy mess.
Got it today. runs good.
I do have the 4 cylinder computer hooked up to 1988 mustang with a V8 5.0 HO 1989 roller motor.
I ran a wire from the hot side of the coil to the 3rd from the bottom wire on the Distributor module plug. Also ran ran a wire on the negative side of the coil to the 2nd from the bottom wire on the distributor module. Ran a hot wire spliced into the hot side of the coil to the ignition. (Here's the trick) Must turn the distributor 3" counter clock wise from the original timed spot and all other Distributor module wires are cut loose. Fuel pump works & the car runs Good!
Thanks for the help
Ira
What is controlling the spark advance for the EFI distributor? There are no working sensors to tell the computer how much to advance the spark. The engine must have proper spark advance for best performance. Running with only the base 10-14 degree timing leaves a lot of HP unavailable.
