HELP 2000 GT Overheating
Punisher512
Hey I have a 2000 GT and recently it has started overheating because the fan does not turn on. I monitor the temperature with the dash diagnostics in the odometer display. Anyway I checked all the fuses and I cant figure out what the problem is. The fan is functional because I applied 12v right to the connector and it ran fine in both speeds. The A/C clutch also does not work. It has been cold here lately, i have been working inside the car so it has been idling for hours sometimes to keep the heat running. The heat still works. I was screwing around drifting in the snow and I ran over a divider.. basically a double curb. All it seemed to do is give the car a good shake. There is no visible damage to the rad support or anywhere under the car. Ever since that incident, the fan has not worked and the car will overheat if not moving. This is starting to piss me off and I need help.
