I have a '67 Mustang and I'm in the midst of a 4-wheel drum to 4-wheel disc conversion. I have a Wilwood adjustable proportioning valve to reduce the pressure on the rears. I'm getting ready to plumb the brake lines and I have a question.
I'd like to run the lines through the stock pressure distribution block, since the existing lines are in good condition.
I would run the brake line for the rears from the MC to the PROP Valve to the DIST. BLOCK.
The line for the fronts would just go from the new MC to the distribution block. That would be the easiest way to plumb it.
Can I use the stock distribution block in this way? Are there residual pressure valves in the stock distribution block that will prevent the disc brakes from working properly? I think I've heard of this before, that drums need a special valve to keep pressure on them so they don't retract too far. Should I just buy a "T" at an auto parts store and use that to split the fronts, and then run from the MC to the prop valve to the rears? If there are residual pressure valves in the stock dist. block, can they be easily removed? What do they look like?
thanks
thanks
