Hello, I'm new to the forum. I have an 1983 mustang gt with a 5.0 out of an 85. It has a edelbrock 4 barrel carburetor (not sure which but could do some research if it is important). When you push the pedal down just a little and at idle it seems like no gas is getting to the motor and it dies (or has a veryyy low inconsistent idle). But if you pump the gas or give it a lot it seems to work just fine. Maybe the first two barrels are clogged? Any help would be appreciated as I'm 17 and learning as I go!
