Help 95 GT wont start
32valvelightning
I just wrapped up my 1995 mustang build it is a 331 stroker with AFR 185 heads, trick flow street heat intake, BBK T/B, MSD distributor and coil, 90mm lightning maf. All the smog equipment is still in place and A/C.
So hear is were the fun began I installed the motor and noticed that when I turned the key on that the electric fan turned on and the CCMR (the one buy the coolant overflow tank) was making a loud buzzing noise. I crank the motor over and it won't start. The ignition has excellent spark but no injector pulse!!!
Replaced the ECM (T4M0) with a know good one still has the same problem.
Any help finding the problem would be greatly appreciated!
