HELP 96 mustang PCM/Pats
So electrical issue fried my pcm,and my pats module. So I'm looking to replace my pcm by purchasing a unlocked version. My question is, if New unlocked Pcm is installed Pats off. Do I still need to replace Pats module and have it plugged in or is there a way around that?
Here's some information about an ODB2 scanner that is capable of re-programming PATS.
ForScan ODB2 scanner w ELM327 USB​
Also for the 1996 model year there's an end user procedure that can reprogram PATS keys. The procedure must be performed EXACTLY and takes 45 minutes to complete. I have posted it many times including at the end of the above URL
And no you don't need to replace anything once PATS has been re-programmed everything will be "in sync".
