  • SN95 4.6L Mustang Tech
Help! alignment with FRPP Csprings....
  • Thread starter Thread starter supastang03
  • Start date Start date May 30, 2006
supastang03
214
Miami/Gainesville UF
May 30, 2006
  • May 30, 2006
its time to get my alignment for my newly installed c-springs, but heres the deal...i live in gainesville right now and there are no custom/modular shops i know of in town, so i must get the alignment at a Midas, firestone etc.. however they cant align my car due to the new springs (they use a computer system that just automatically knows the specs for each car), but now my specs are different, due to the springs. anyone know where i can get the specs for the c-springs so he can do it manually...or what should i do...?
jeffnoel
1,638
Clovis, CA
May 30, 2006
  • May 30, 2006
When I did my C springs I took it to the local Goodguys shop that uses the same computerized mirrors mounted on the wheel thing and had no problems setting it to factory specs.
supastang03
214
May 30, 2006
  • May 30, 2006
yea but that is my question...are you supposed to set it back to factory settings, now that the car is lower, wouldnt it need a different set of specs, or different setting..?
tomustang
Psychotic Member
3,434
McLean Hospital
May 30, 2006
  • May 30, 2006
They are just being lazy
P
Pennywise2
Banned
May 16, 2006
1,379
  • May 30, 2006
I highly subjest a alignment after springs.You should look around
other areas to see if you can find a place to get a alignment done.
Nater
239
Maplewood, MN
May 30, 2006
  • May 30, 2006
I put the C springs on my car and when it was taken to the shop to have them align it, it was not that far off from the factory marks. I think they are giving you a bunch of BS.
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
May 30, 2006
  • May 30, 2006
everyone lacks reading comprehension.
set it back to factory specs.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 30, 2006
  • May 30, 2006
you use the factory specs unless you are making it into a track car. the only thing i run diff is a little more negative camber and i maxed out positive caster.
RaceDvr50
121
Coon Rapids
May 30, 2006
  • May 30, 2006
Yes they are all right factory specs are what you are looking for. If some moron can't handle that you have aftermarket parts in your car just leave and go to the next place. I'm so tired of so called techs not even being able to mount a damn tire right anymore. If they can't get it right you may need caster camber plates but they should be able to get it right without them.
supastang03
214
May 31, 2006
#10
  • May 31, 2006
  • #10
yea thats what i thought. he said they can do it with the factory specs, but that it may come out wrong. i guess he was wrong. thanks for all the feedback guys!:SNSign:
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
ECU help!
  • starkiller1134
  • Aug 16, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
Security help
  • 05turboturdpt
  • Aug 19, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 28, 2025
05turboturdpt
