hey guys whats up....i got a 88 5.0 that i bought about 6 months ago ago and just now gettin ready to drive it
a few weeks ago i took it to the car wash and when i was coming out i kinda gunned it a little (ok alot) but nothing i know it cant handle (this is my third one) and now it has a bad and steady miss vibration under any load...it has 215k miles and i bought it from the original owner than took pretty good mechanical care of it it is a little leaker but thats nothing big....anyhow i have replaced the plugs (.054) wires cap rotor and coil and still nothing...dist is good teeth are good timing is *14 on the nose and advances steadily...the motor mounts from what i can see however seem to be chipping away...im thinking maybe i ripped it the rest of the way when i did that...car has good power it seems though i havent driven it much since that happened and when i have not very hard....idle is rock solid and when free revving sounds strong and relatively smooth so i just dont see how it could be a miss...i know it could be a ton of things but i was hopin somebody on here had some pointers...it almost sounds like a cylinder isnt firing but im sure it is cause the miss goes away when not under load....any ideas guys?? i havent had a chance to drive this car since i bought it in may....HELP!!!!!!
other things-
-i have a new fuel filter that i havent had a chance to install yet.
-fuel pump is good
-balancer looks good
a few weeks ago i took it to the car wash and when i was coming out i kinda gunned it a little (ok alot) but nothing i know it cant handle (this is my third one) and now it has a bad and steady miss vibration under any load...it has 215k miles and i bought it from the original owner than took pretty good mechanical care of it it is a little leaker but thats nothing big....anyhow i have replaced the plugs (.054) wires cap rotor and coil and still nothing...dist is good teeth are good timing is *14 on the nose and advances steadily...the motor mounts from what i can see however seem to be chipping away...im thinking maybe i ripped it the rest of the way when i did that...car has good power it seems though i havent driven it much since that happened and when i have not very hard....idle is rock solid and when free revving sounds strong and relatively smooth so i just dont see how it could be a miss...i know it could be a ton of things but i was hopin somebody on here had some pointers...it almost sounds like a cylinder isnt firing but im sure it is cause the miss goes away when not under load....any ideas guys?? i havent had a chance to drive this car since i bought it in may....HELP!!!!!!other things-
-fuel pump is good
