HELP! bad vibration
  • Thread starter Thread starter redfox91
  • Start date Start date Aug 26, 2007
1 of 2 Next Last
R
redfox91
94
Northwest Arkansas
Aug 26, 2007
  • Aug 26, 2007
I am having a bad vibration when I get up around 60 plus? It doesnt matter what gear im in and its not my tires??? I was thinking driveshaft or yoke or u-joint??? help me out
squeak93
2,352
418
164
Joplin, Missouri
Aug 26, 2007
  • Aug 26, 2007
Most likely the u joints. Have they ever been replaced???
If not do it soon. Losing a drive shaft on the hwy can get u hurt or killed!
88mouse
630
Mooresville nc
Aug 26, 2007
  • Aug 26, 2007
Where do you feel it at in the steering wheel or the bottom of the seat?
71swing
199
Omaha,NE
Aug 27, 2007
  • Aug 27, 2007
Good Question:
It could just be a unbalanced tire.
R
redfox91
94
Northwest Arkansas
Aug 27, 2007
  • Aug 27, 2007
its not the tires for sure, and the vibration is coming from under the seat.
88mouse
630
Mooresville nc
Aug 27, 2007
  • Aug 27, 2007
Start off by checking the u-joints. If not there i would say a bad bearing in the rear end. Why are you so sure that its not a tire vibration? Friend of mine just had two front tires put on and balanced, took the wheels home and put them on the car and took off down the road, could hardly hold the steering wheel it was so bad. So i took them up to where i work and check the balance one was out by 4 1/2 oz and the other was out by 1 1/2oz. So just because you just had them balanced or what not don't rule it out.
R
redfox91
94
Northwest Arkansas
Aug 27, 2007
  • Aug 27, 2007
Oh I know what you mean, but my best friend owns a tire shop and he just checked them for me again on saturday. Question, If the drive shaft is taken out and not marked and then put back in not in the same position would that throw it off?
cenok is family
1,409
69
79
Norman, Ok
Aug 27, 2007
  • Aug 27, 2007
my car does the same thing 'cept it starts around 70-75ish. i'm about 90% sure it's my u-joints. i'm just gonna get an aluminum driveshaft though, don't wanna waste the money on u-joints just to turn around and get a new driveshaft.
R
redfox91
94
Northwest Arkansas
Aug 27, 2007
  • Aug 27, 2007
I think it could be the way the driveshaft is bolted to the flange at the rear end??? Does this make sense?
88mouse
630
Mooresville nc
Aug 27, 2007
#10
  • Aug 27, 2007
  • #10
Yeah that can cause it to. Had that probablem a few times on my gt. Take it back out and turn it 180*.
R
redfox91
94
Northwest Arkansas
Aug 28, 2007
#11
  • Aug 28, 2007
  • #11
Well I turned the driveshaft, replaced the u-joints, took it to another place to check the balance on the tires???? I cant figure it out. Any help would be great
R.J.
813
Warwick, Rhode Island
Aug 28, 2007
#12
  • Aug 28, 2007
  • #12
Any rear end work done recently?
R
redfox91
94
Northwest Arkansas
Aug 28, 2007
#13
  • Aug 28, 2007
  • #13
Yes I did just have new gears put in with a master bearing kit... But it seams like if that were the problem then it would vibe all the time or howl???
Mustangr
217
boise Id
Aug 28, 2007
#14
  • Aug 28, 2007
  • #14
I have vibration in my steering wheel. I am pretty sure that it is a slight bent rim. Could you have bent your rim in anyway?
R
redfox91
94
Northwest Arkansas
Aug 29, 2007
#15
  • Aug 29, 2007
  • #15
Not at all I am positive on that one...
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Aug 29, 2007
#16
  • Aug 29, 2007
  • #16
I vote for U joints.
R.J.
813
Aug 29, 2007
#17
  • Aug 29, 2007
  • #17
How were your wheels balanced?
Check out this web site and see if there is one of these machines near you. This will rule out tires and wheels, for sure.
http://www.gsp9700.com/
L
LAZERREDGT
254
South Texas-(Rio Grande Valley)
Sep 6, 2007
#18
  • Sep 6, 2007
  • #18
I have the same prob., just that the shifter shakes at around 2500-3000 rpms. Any idea?
cjones
1,561
Avondale, AZ
Sep 7, 2007
#19
  • Sep 7, 2007
  • #19
when you had the driveshaft out, did you have it balanced?? maybe when the gears were put in the shaft got dented.
Dachipsta
35
12
#20
  • Sep 7, 2007
  • #20
Had the same problem a couple years ago. Had a vibration that seemed to oscillate from the front to the back at around 70-80mph. Went thru the whole tire balancing routine also. Changed out DS to a new Motorsport alumninum one and problem solved. I suppose it could have been one or both of the u-joints but as easy as it was to change out the whole thing in one shot rather than d--kin around with u-joints, it wasnt worth my time to find out..........l8r
FWIW, I had that same 2500-3000 RPM vibration as well. I changed out the stock balancer for a PP unit and replaced both motor mounts. The balancer was starting to give up and the vibration was amplified because of the dead motor mounts.
1 of 2 Next Last
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
