HELP! bad vibration
  • Thread starter Thread starter redfox91
  • Start date Start date Aug 26, 2007
First Prev 2 of 2
6SpeedLX
100
Mass
Sep 7, 2007
#21
  • Sep 7, 2007
  • #21
if you could get a hold of an Electronic Vibration Analyzer, this would be a lot simpler.. a few readings from the screen, some math and *bam!!* theres your answer. if you can find a Ford tech (i think any dealership should have one), see if he can get his hand on the EVA, theres a new one out now thats more advanced, i forget what its called..so im sure they wouldnt notice the old EVA missing for a day.
thats the way i would go about it if youve already ruled out the obvious
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 7, 2007
#22
  • Sep 7, 2007
  • #22
How about a harmonic balancer?
R.J.
813
Warwick, Rhode Island
Sep 13, 2007
#23
  • Sep 13, 2007
  • #23
Any update on fixing the problem?
seanw
1,100
36
58
Colorado Springs, CO
Sep 13, 2007
#24
  • Sep 13, 2007
  • #24
If the problem is at 2500 rpm in any gear, then it's not the driveshaft or the wheels. I'd suspect that the outer ring of the harmonic balancer slipped. The 5.0's are pretty notorious for doing just that.
G
green9250
#25
  • Mar 25, 2008
  • #25
I have a 92 lx and It started after new headers, motor mounts, I have "seat" vibration at about 40 -50 MPH U joints are fine but it looks like the balancer has a wobble I have had the tires balanced too
this drives me crazy
long story short _ driveline was out of balance!!
cjones
1,561
Avondale, AZ
Mar 25, 2008
#26
  • Mar 25, 2008
  • #26
if you mean the harmonic balancer on the crank then it's probably time to replace it. they are a 2 piece unit and when they start to come apart the wobble and vibrate the car.
if you mean the tire balance has a wobble and the rims are straight, then the tires would need to be replaced or possibly load balanced.
seat vibration is usually engine, driveline or rear tires.
First Prev 2 of 2
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
