HELP!!! Big problem
  • Thread starter Thread starter ALMOSTFINISHED
  • Start date Start date Mar 14, 2006
ALMOSTFINISHED
315
Westchester County NY
Mar 14, 2006
  • Mar 14, 2006
Ok here goes.
I bought the aluminum cyl heads from www.tristatecylinderhead.com for my car. Apparently they have 2.02 intake valves. I am seeing that some people say they will not work with my stock shortblock but then I am seeing that some people have run eddy's with the 2.02 intake valves. I was looking into the F-cam but was told that would not work. Would the TFS stage 1 cam work without having to flycut the pistons or should I just stay with a stock cam? I need help asap. Or am I SOL on this in all aspects? Please help...
Nick
ALMOSTFINISHED
315
Mar 14, 2006
  • Mar 14, 2006
BUMP
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Mar 15, 2006
  • Mar 15, 2006
i may be wrong but i was under the impression that the 88 mustangs had fly cut pistons. only the 86 fuel injected 302's didn't.
M
Mike92GT
583
Florida
Mar 15, 2006
  • Mar 15, 2006
Only way to know for sure is to set it up with clay and check the piston to valve clearance. Generally speaking, 2.02 valves will not clear stock pistons, the only exception is TFS heads. There is a jig available that will allow you to flycut the pistons without removing them.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
