My son's 99 Cobra has apparently blown a rod bearing. So say the small local auto mechanic. (Fairly loud metallic rap, about 2Hz at idle, rpm dependent, rear drivers side of the engine. Sometime it will go intermitant for a brief second or 2). Ruled out Tranny/Bell housing. Ruled out the Passenger side valve train. Engine has 60K on it.
Getting beyond the exact cause, I am preparing for the worst... Engine will come out, and while I am at it might as well invest a little.
I am corvette guy by nature. I know who the big reputable tuners are in that world, and what can be done with LS1/LS6's... In the land of Mustang talk, I admit I am totally novice, and appreciate any advice.
What are the stroke/boring options with this 4.6L?
My goals are:
1) To keep the enging serial number consistent with the car.
2) I do NOT want to cut or invest in new hoods.
3) No bolt ons for forced air, but I am flexible on this one.
4) My goal is to increase the 315-320 stock ponies... Perhaps as high as 400HP. I am not looking for a drag rocket. I want reliable, streetable power. Can this block be bored to 5.0L ? Who makes the sleeves? Rods/Piston recommendations? Porting Heads ? Cam recommendations?
How much money will take to get there?
Any people within 300 miles of Jacksonville, FL you would recommend?
Thanks in Advance.
My goals are:
Thanks in Advance.
