Need Help With 4.6 Emission Problems
Ranco
I have a check engine light on a 1997 Tbird 4.6 which I am having difficulty resolving. I have been on a Tbird site for a while but I am getting some confusing suggestions, so I thought I would check out the Mustang experts. The 97 Bird 4.6 has 201,xxx miles. DTC codes P0172 and P0175 "rich both banks" occurred just after 200K and I have been chasing this problem for quite a while. So far I have checked for vacuum leaks and corrected a few minor ones. A friends scanner indicated fuel trims over -15 to 25 range when the engine was hot and noted the hotter the engine got the worse the fuel trims got. The cooling fan seemed slow to come on so I replaced the ECT and IAT sensors. I swapped the purge solenoid and still no improvement. I then had a "professional" scan which indicated the MAF was "slightly" out of spec so I replaced the MAF. Fuel pressure was found to be within range. The professional exhausted his list of items to check and ended up with fuel injectors as the problem and suggested using a cleaner to possibly free a stuck injector. Done with no improvement. Lastly, I just swapped out the CCRM from my other 97 Bird to see if the temp issue could be the cause. After 3-4 restarts the CEL was back and so was the P0172 code. No doubt if I drive some more the P0175 will return.
I have read many posts on other sites and I believe I have checked or replaced all the suggested causes, except for replacing the O2 sensors (which do not seem to be the problem according to the websites) and replacing the injectors. One commenter suggested the O2 sensors should have been replaced at 60K. The car runs good with no performance issues although gas mileage does seem to be less than normal. I am not a novice mechanic but not an expert either, especially with all the computer controls on these models.
I am getting ready to Seafoam the engine to see if that helps.
Any suggestions would be appreciated. Sorry for the long post but I thought more info the better.
A couple of things.
Is the fuel pressure regulator intake vacuum reference line connected and leak free? Is there any evidence of gas in the line.
Exactly HOW did you check the fuel pressure? What was the value and test conditions? What is the fuel pressure at idle with the intake vacuum reference connected? And then disconnected?
Does the exhaust SMELL rich?
For injector problems I have had GREAT success using the InjectorRX.com cleaning/flow test service. Once cleaned and tested they are as good as new. Cheaper than new. The best part is there will be a report documenting each injector is flowing within balance specification.
If there is more than 60K miles on the O2 sensors, you should consider replacing them...
Here's some help in that arena...
Code 41 or 91. Or 43 Three digit code 172 or 176 - O2 sensor indicates system lean. Look for a vacuum leak or failing O2 sensor.
Although this was written with the fox body 5.0 Mustangs in mind, there is some commonality , and this is one of the areas.
Revised 11-Jan-2015 to add check for fuel pressure out of range
Code 41 is the passenger side sensor, as viewed from the driver's seat.
Code 91 is the driver side sensor, as viewed from the driver's seat.
Code 172 is the passenger side sensor as viewed from the driver's seat.
Code 176 is the driver side sensor, as viewed from the driver's seat.
Code 43 is not side specific according to the Probst Ford Fuel injection book.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Testing the O2 sensors 87-93 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear.
Disconnect the O2 sensor from the harness and use the body side O2 sensor harness as the starting point for testing. Do not measure the resistance of the O2 sensor , you may damage it. Resistance measurements for the O2 sensor harness are made with one meter lead on the O2 sensor harness and the other meter lead on the computer wire or pin for the O2 sensor.
Backside view of the computer wiring connector:
87-90 5.0 Mustangs:
Computer pin 43 Dark blue/Lt green – LH O2 sensor
Computer pin 29 Dark Green/Pink – RH O2 sensor
The computer pins are 29 (L\RH O2 with a dark green/pink wire) and 43 (LH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
91-93 5.0 Mustangs:
Computer pin 43 Red/Black – LH O2 sensor
Computer pin 29 Gray/Lt blue – RH O2 sensor
The computer pins are 29 (LH O2 with a Gray/Lt blue wire) and 43 (RH O2 with a Red/Black wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Testing the O2 sensors 94-95 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a red/black wire) and 27 (RH O2 with a gray/lt blue wire). Use pin 32 (gray/red wire) to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
Testing the O2 sensor wiring harness
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer. Using the Low Ohms range (usually 200 Ohms) you should see less than 1.5 Ohms.
87-90 5.0 Mustangs:
Disconnect the connector from the O2 sensor and measure the resistance:
From the Dark blue/Lt green wire in the LH O2 sensor harness and the Dark blue/Lt green wire on the computer pin 43
From the Dark Green/Pink wire on the RH Os sensor harness and the Dark Green/Pink wire on the computer pin 29
91-93 5.0 Mustangs:
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 43
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 29
94-95 5.0 Mustangs:
Computer pin 29 Red/Black – LH O2 sensor
Computer pin 27 Gray/Lt blue – RH O2 sensor
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 29
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 27
There is a connector between the body harness and the O2 sensor harness. Make sure the connectors are mated together, the contacts and wiring are not damaged and the contacts are clean and not coated with oil.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
Check the fuel pressure – the fuel pressure is 37-41 PSI with the vacuum disconnected and the engine idling. Fuel pressure out of range can cause the 41 & 91 codes together. It will not cause a single code, only both codes together.
Make sure you have the proper 3 wire O2 sensors. Only the 4 cylinder cars used a 4 wire sensor, which is not compatible with the V8 wiring harness.
Replace the O2 sensors in pairs if replacement is indicated. If one is weak or bad, the other one probably isn't far behind.
Code 41 can also be due to carbon plugging the driver’s side Thermactor air crossover tube on the back of the engine. The tube fills up with carbon and does not pass air to the driver’s side head ports. This puts an excess amount of air in the passenger side exhaust and can set the code 41. Remove the tube and clean it out so that both sides get good airflow: this may be more difficult than it sounds. You need something like a mini rotor-rooter to do the job because of the curves in the tube. Something like the outer spiral jacket of a flexible push-pull cable may be the thing that does the trick.
If you get only code 41 and have changed the sensor, look for vacuum leaks. This is especially true if you are having idle problems. The small plastic tubing is very brittle after many years of the heating it receives. Replace the tubing and check the PVC and the hoses connected to it.
Check out the P0175 code at https://www.obd-codes.com/p0175
A couple of things.
The fuel pressure was checked by gauge attached to fuel rail. This was done by a mechanic friend who said the pressure was within parameter but I don't know the actual numbers. I lost my sense of smell due to chemotherapy but there is no residue in the exhaust pipes that would indicate an overly rich condition. And no one has indicated they smelled any problem. There has been no problem with performance that would suggest fuel pressure as a problem. No stumbling on accel, no rough idle. There has been one issue with the engine revving at stop which has been associated with the IAC. The engine would also rev at stop just after shifting into park on almost every occasion. After cleaning this seems to have stopped.
I have to check the regulator intake vacuum line for leaks - next on my list.
87-90 5.0 Mustangs:
91-93 5.0 Mustangs:
87-90 5.0 Mustangs:
91-93 5.0 Mustangs:
94-95 5.0 Mustangs:
WOW- a lot more info than I got from the Tbird site. It will take some time for me to review and digest this info. THANKS.
