  • 1994 - 1995 Specific Tech
HELP! Blown injector O-Ring???
  • Thread starter Thread starter AznStanger3v
  • Start date Start date Sep 14, 2004
AznStanger3v
2,026
Northern VA
Sep 14, 2004
  • Sep 14, 2004
Hey guys, i need help realllllly quickly. I just put in my adjustable fuel pressure reg. and put the guage on. I put my fuel pressure to 38. I decided that i wanted to run around with the guage always on. Im driving back from Target and i smell this horrid smell of gas. I pull over and the injector under the guage (#1 cylinder) is spitting fuel out. I push the rail back down and when i start it up, the rail raises up and the injector starts spitting it out. I took off the guage and tried it to no avail, same damn results. Is it possible i blew out the TOP o-ring????? That is going to piss me off if i did. thanks in advance.
How i got home:
I wrapped a big flashlight in two t-shirts and used the hood to put force on the rail.
AznStanger3v
2,026
Northern VA
Sep 14, 2004
  • Sep 14, 2004
this **** isnt going to the bottom of the barrel just yet.
Redsnk95
2,243
Houston, TX
Sep 14, 2004
  • Sep 14, 2004
Been there done that...go to AutoZone or O'Reilys and get some o-rings.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 14, 2004
  • Sep 14, 2004
Sounds like an o-ring has taken a poop. Take the injector out and go to your local parts store and ask for the same size o-ring(don't forget to take your old one with you). Pair with the same size and your good.
AznStanger3v
2,026
Northern VA
Sep 14, 2004
  • Sep 14, 2004
How come it suddenly decided to do this now after i put in the regulator and guage??? Any ideas?
SN95StangMan
1,292
Lynwood, CA
Sep 14, 2004
  • Sep 14, 2004
I had a similar problem after installing my intake. Only I had a bad o-ring AND I forgot to put back one of the bolts the holds the fuel rails.
I zip tied the bastard down so that I was able to get back home. God bless zip ties.
Dave95GT
bAd mUtha
477
Looking for all of my missing posts
Sep 15, 2004
  • Sep 15, 2004
Get an injector rebuild kit, its about $2
R
Road_Runna
20+ Year Stangneter
Dec 23, 2002
594
Ogden, UT
Sep 15, 2004
  • Sep 15, 2004
Goto NAPA, I can't remember what the kit is called "Pintle" something.
But NAPA should have it, and it's cheap.
SuperSync
241
Asheville, NC
Sep 15, 2004
  • Sep 15, 2004
Might as well re-ring all your injectors on that rail (there are o-rings on the top and bottom of each injector).
It's pretty cheap to do and since you'll lift the rail you might as well. That side is pretty easy to do. I had one start squirting gas on my driver's side a couple winters ago when it was like 10*F with 30 MPH windows outside. It was cold even in the garage.
Put some petroleum jelly on the rings so they'll slide right on the top and bottom of the injectors.
SS
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Sep 15, 2004
#10
  • Sep 15, 2004
  • #10
You probably jiggled the rail, which messed up an already dry-rotted O-ring. If you go to Advance or the Zone, you can ask for an injector O-ring kit. They will be able to look it up by application, no need to bring in an old O-ring. You will need two of them to do all the injectors. It is easy to do. You have to remove the upper intake. There are just 4 bolts holding the rail down. Remove the rail, and change the O-rings. Shouldn't take more than an hour and a half.
Kurt
AznStanger3v
2,026
Northern VA
Sep 15, 2004
#11
  • Sep 15, 2004
  • #11
re ringing it isnt a problem for me at all. I just really dont want to seeing how i can only start at 5 pm and i have school starting next week. this sucks ass
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 1:55 PM
skidad
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
J
Spuddeeing 06 4.0!
  • jester242
  • Dec 22, 2025
2005 - 2014 S-197 Mustang -General/Talk- Dec 22, 2025
jester242
J
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
