  • SN95 4.6L Mustang Tech
Help! Brake question
  • Thread starter Thread starter KnightHawks97
  • Start date Start date Jan 19, 2004
K
KnightHawks97
9
  • Jan 19, 2004
I am trying to replace the front pads on my 99 mustang. I am right now working on the lower bolt on the caliper as shown in the picture, but now matter how much I turn the bolt it just stays in place! I mean it turns, but it just won't come out! IS this normal? What am i doing wrong???? Thanks.
C
claytucc3
825
Santa Clarita, Ca
Jan 19, 2004
  • Jan 19, 2004
that metal piece behind the red part of the caliper has a flat edge put an adjustable wrench on it and then turn the screw.
K
KnightHawks97
9
  • Jan 19, 2004
that would explain it! thanks i'll try it now
K
KnightHawks97
9
  • Jan 19, 2004
i just went out and tried it, but I couldn't find any flat edge. the part that turns as i turn the bolt is round, and I can't grab it with a adj wrench or pliers. it just turns and turns.
C
claytucc3
825
Santa Clarita, Ca
Jan 19, 2004
  • Jan 19, 2004
You need to hold that somehow. If you ar not going to turn the rotors which I wouldn't suggest you can just tilt the calpier up and change the pads but I wouldn't change the brakes w/o turning the rotors. are those stock Calipers painted red or the bullit ones?
K
KnightHawks97
9
  • Jan 19, 2004
actually i got that picture from another site, i think those are stock calipers painted red. i just have the stock ones on.
i am probably gonna use a vice grip and latch on to it. my only concern is that i may damage the round piece and rubber part if i use to much pressure on it.
i think i may just cut out the rubber piece, so i could get a better grip on the round metal piece. it seems to be just there with no real purpose. will that affect anything? or should i leave the rubber part in place?
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sunday at 3:35 PM
Boats90GT
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
