Electrical Help! Can't Tell If Tranny Or A Battery Problem.
DeBass87
I have a 95 GT Convertible (automatic) and I'm currently having problems getting my car to shift. It seems to be very sometimey with it. I read it might be the battery and tried the recommended disconnecting the battery trick which for a moment worked. I took a drive, stopped at a gas station and when I fired her back up boom back to not shifting again.
This problem has only been going on for about a week where it seems some days it cooperates and sometimes it does not. I've filled the Transmission and I check it everyday just to make sure there's been no leaks that I can't see and the levels are fine, though before I knew how to read the thing properly it was pretty low for like a week, although it didn't see too much driving.
Normally I'm shifting at about 2500, after resetting the battery it first took till 3000rpm before it shifted. I hope I covered the basics in describing the problem.
I've read somewhere that bad batteries can cause problems with the car not knowing when to shift, the battery was tested and its just fine.
Once the engine is running, the alternator supplies the electrical power to run the car. The primary duty of the battery is to provide power to crank the car.
Free and inexpensive things you can do:
1.) Free: have your local auto parts store do a check of the battery and charging system.
2.) Inexpensive: Dump the codes. Since you have a AODE, it may have dropped some code evidence in the computer. A scanner or code reader isn't needed to dump the codes.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus Digital Ford Code Reader (3145) Equus - Digital Ford Code Reader 3145.
It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.
