HELP!!!!!Car Trouble
ilovestangsalot
hey i need help my car is an 89 gt it is strong and runs good except for at least once a day a loud popping noise comes for the tranny area while driving it is a manual and it feels like a binding and jerks the car slower like u slam on the brakes for a split second so i got the tranny rebuilt and it still does it maybe they missed some thing i also thought it could be the right caliper cause the rotor got eatin up after 5000 miles of being turned so i replaced that but it still does it i need help has anything like this happened to yall hit me back if u got any ideas i am open to suggestions
Gonna need a little more info then just that.
Cheap thing to check out would be the rear gears. I had a gear eat a tooth and it did a pop like that. Besides, its more then likely time to change your gear lube anyway!
periods. are. your. friends.
try this:
Upgrade the stock rubber caliper slide pin bushings to metal ones.
Reason being the stock rubber bushings let the calipers move during braking, so the pad doesn't contact the rotor squarely. This movement reduces braking effectiveness, and causes uneven pad wear from pad cocking under hard braking. You will not notice a lot of difference around town, but at highway speeds you can tell the car slows down quicker. [ installation info] These bushings work on the stock calipers and the SVO 73mm calipers, but not the newer SN95 calipers.
i had the same problem once. i hope its not the same for you.i was going down the highwayone day and it was like someone pulled the parking brake and let off. at first i thought the parking brake cable got caught on the driveshaft, so i looked and saw a dent in the diff cover, the car was driveable so i kep driving it. it did it again so i looked again and now i was leaking gear lube. i pulled the cover off and one of the spider gears were broke off the pin. i ended up cutting the carrier out because the pin was too f*&@#d up to get out.
hope i didnt scare ya
hey
the poping noise is up front in the center. it is not a u joint and only does it under load at low rpm maybe it is lean fuel but why would it pop im going to clean the injectors i was aolready going to change the gear oil so ill do that soon to. any more ideas. i just replaced the calipers and rotors yesterday that cant be it it is in the center. it could be the rearend and the noise is just going up the drive shaft to sound as if it were the tranny.?!! that is what i thou8ght it was at first
When my 7.5 rear ate itself alive, I thought the tranny was going to explode. Grinding noises in the center of the car and the whole shifter was shaking like the tranny was going to drop on the pavement. Replaced the shredded ring and pinion in the rear and it was back to normal.
-Mike
i replaced my reaR end oil today everything was ok. it was a pain in the ass to get the fliud back in that sucked if everything could go wrong it was but at least i am not gay like 85_ss_302_coupe cause i hate him
