Fuel Help - Car Won't Start After Braided Fuel Line Conversion
93tankus
MI
Hi All,
So, I'm hoping to get some help. I have a 302 with the BBK High Flow fuel rail system. I replaced the rubber hoses that came with that unit with some braided line. However, when I went to start it back up, it sputters and dies. Or, it doesn't catch at all.
Things that I've checked so far:
- Made sure there was gas in the car! LOL
- Pulled the supply braided line to make sure that fuel was getting to the rail. It is.
- Pulled the braided line off the return (regulator) to see if there was fuel coming out. There was...but it was intermittent. Not sure if it should be a constant steady stream (like the supply line)?
Things that I'm concerned about:
- I had to briefly remove the distributor to gain access to the fuel rail supply. I noted and marked the position before I removed it. I'm concerned that I messed up the timing.
- That some debris somehow got into the fuel rail during my work and clogged the fuel injectors.
Questions:
- Should the return fuel line coming out of the fuel rail have a consistent stream of fuel? Could there be a blockage in there that is making the flow intermittent?
- I felt like I got the distributor back in as it was. But...maybe it's off a few degrees? Would that preclude the car from starting at all? If the timing was off...would it just run rough (assuming it was off a few degrees)?
I have a track day coming up (of course!)....and I'd love to get it running. Any help or guidance would be super appreciated!
Thanks!!!!!
  • Sponsors(?)
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,248
2,595
234
74
Dublin GA
lowendmac.com
Hi All,
Questions:
Thanks!!!!!
It’s Decision Tree time:
No spark = go to step #1 & 2.
Good spark - what is a good spark can be a subjective judgment. If you have any doubts, borrow a known good coil from another pre 1996 Ford.
If you do have good spark = go to step # 3
Engine fires off and then dies = go to step # 4
Make sure that you have fuel pressure when the engine fires off. Leave the fuel pressure gauge connected while testing so that you can observe what the fuel pressure is doing.
Fuel pressure OK while cranking
Go to step # 5
Be sure to use a noid light to see if the injectors are pulsing. Use the most accessible fuel injector connector for the noid test.
Noid light pulses and fuel pressure is good.
Go to step #6
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 26-Jul-2017 to add fuse link diagram.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the Ignition switch wiring diagram for more information on the ignition wiring fuse link because it is the next thing to be tested. You will need a Multimeter or DVM and know how to use the Ohms function to check continuity between the red/green wire on the ignition coil and the red/green wire on the ignition switch. Make sure that the ignition switch is in the off position when you do the check. You should see less than 1 Ω (Ohm) between the red/green wire on the coil and the red/green wire on the ignition switch. More than 1 Ω means that the fuse link may have blown open and needs to be replaced. If you get 1 Ω or less means the fuse link is OK and the ignition switch is bad.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Reactions: 93tankus
93tankus
MI
This is suuuuuper helpful information, jrichker!!! Thank you!!!
I'm concerned that maybe I goofed up the timing when I temporarily removed the distributor. It's an MSD Pro Billet, for what it's worth. I'm just wondering if that being off just a few degrees would preclude the car from starting?
Like I said, it sometimes starts, sputters, and dies.
Thanks SO much for your help!!!!
jrichker
Mar 10, 2000
27,248
2,595
234
74
Dublin GA
lowendmac.com
Go through the checklist and fix whatever you find that is wrong. Then and only then do the following...
Putting the distributor back in and setting the timing.
Revised 28-Apr-2018 to add photo & description of the SPOUT connector and SPOUT jumper .
You can forget about anything beyond this point if you don't have access to a timing light. You will never get the timing set right without one.
Note: If you don't have access to a timing light, most of the larger auto parts stores will rent or loan one if you have a credit card or leave a cash deposit.
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole, crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block, (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing.
If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that there is no such thing as one tooth off on a 5.0 Mustang if you follow the spark plug wire order on the distributor cap. If it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range. If the TFI prevents the distributor from being turned enough to get 14°, there is a simple fix. Pull the distributor out and turn the rotor 1 tooth counterclockwise Don't move the wires from the positions shown on the cap on fuel injected engines!!!! The #1 position cast into the cap MUST have the spark plug wire for #1 cylinder in it. Do it differently and the timing for the fuel injectors will be off. The computer uses the PIP sensor to time injector operation by sensing the wide slot in the PIP sensor shutter wheel. If the injector timing of #1 and the firing of #1 do not occur at the right time, the injector timing for all other cylinders will be affected.
Setting the timing:
Paint the mark on the harmonic balancer with paint -choose 10 degrees BTC or 14 degrees BTC or something else if you have NO2 or other power adder. I try to paint TDC red, 10 degrees BTC white and 14 degrees BTC blue.
10 degrees BTC is towards the drivers side marks.
Note: setting the timing beyond the 10 degree mark will give you a little more low speed acceleration. BUT you will need to run 93 octane to avoid pinging and engine damage. Pinging is very hard to hear at full throttle, so it could be present and you would not hear it.
Simplified diagram of what it looks like. Not all the marks are shown for ease of viewing.
ATC ' ' ' ' ' ' ' ' ' '!' ' ' ' ' ' ' ' ' ' BTC
---------------- > Direction of Rotation as viewed standing in front of the engine.
The ' is 2 degrees.
The ! is TDC
The ' is 10 degrees BTC
Set the timing 5 marks BTC. Or if you prefer, 5 marks towards the driver's side to get 10 degrees.
To get 14 degrees, set it 7 marks BTC. Or if you prefer, 7 marks towards the driver's side to get 14 degrees.
The paint marks you make are your friends if you do it correctly. They are much easier to see than the marks machined into the harmonic balancer hub.
At this point hook up all the wires, get out the timing light. Connect timing light up to battery & #1 spark plug. Then start the engine.
Remove the SPOUT jumper
It is the 2 pin rectangular plug on the distributor wiring harness. Only the EFI Mustang engines have a SPOUT. If yours is not EFI, check for a SPOUT: if you don’t find one, skip any instructions regarding the SPOUT. The SPOUT (Spark Out) enables the computer to control the spark advance. When the SPOUT is removed, the ignition timing reverts to the base ignition timing set by either the spark rod inside the distributor or the physical position of the distributor.
Warning: there are only two places the SPOUT should be when you time the engine. The first place is in your pocket while you are setting the timing and the second is back in the harness when you finish. The little bugger is too easy to lose and too hard to find a replacement.
Start engine, loosen distributor hold down with a 1/2" universal socket. Shine the timing light on the marks and turn the distributor until the mark lines up with the edge of the timing pointer. Tighten down the distributor hold down bolt, Replace the SPOUT connector and you are done.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
Thread starter Similar threads Forum Replies Date
L AIRBAG HELP, CAR WON"T START Fox 5.0 Mustang Tech 4
M HELP!!! CAR WON"T TURN OFF!!! Classic Mustang Specific Tech 3
D Supercharger installed, CAR WON"T START. HELP PLEASE SN95 4.6L Mustang Tech 6
B Need some help cars not right SN95 V6 Mustang Tech 1
G troubleshooting help car is stumbling and lean 1994 - 1995 Specific Tech 1
T HELP MY CAR IS RUNNING TERRIBLY! 1996 - 2004 SN95 Mustang -General/Talk- 1
A Electrical Help. I’ve about had it with this car.... Fox 5.0 Mustang Tech 12
trlps_ Need help, car wont rev up or drive 1996 - 2004 SN95 Mustang -General/Talk- 2
Wayne Waldrep Engine Trouble with the old pile...I mean car. Need some help. Fox 5.0 Mustang Tech 7
D Car is going haywire! Help. 1996 - 2004 SN95 Mustang -General/Talk- 1
B Coolant eruption... car cranks but won’t start... HELP please! SN95 V6 Mustang Tech 5
Taylor F Deciding first car HELP!!! The Welcome Wagon 27
B Engine Plz help ready to set car ablaze Fox 5.0 Mustang Tech 7
M New project car help - engine head bolt size? 1965 - 1973 Classic Mustangs -General/Talk- 1
Rynb15 Picked up an 85gt, need help with year of motor in car/firing order 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
starstruck106 Car overheated and now it won't turn over - help PLEASE 1994 - 1995 Specific Tech 51
R Need help with car dying SN95 4.6L Mustang Tech 2
1 Electrical Car running like crap, HELP! Fox 5.0 Mustang Tech 20
Mustang Christine Car dies in idle?? Out of ideas?? Please help!! 2005 - 2014 S-197 Mustang -General/Talk- 2
K Car wont start help! 1996 - 2004 SN95 Mustang -General/Talk- 2
Vaughnmx Engine 1990 fox car runs great unti it goes into closed loop runs vary rough popping backfire no power please help Fox 5.0 Mustang Tech 14
T 2008 Mustang GT Vibration in Entire Car 2005 - 2009 Specific Tech 5
M Mustang 2002 Idle/ starting the car when the engine is hot problems. ( help ) 1996 - 2004 SN95 Mustang -General/Talk- 8
S So guys need help. Want to get my car tuned. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
L Help identifying heads on new car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
Z 79 Pace Car 5 lug swap Help. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
G (Help) Car Wont Run : Mass Air Conversion 1986 Mustang Issues Fox 5.0 Mustang Tech 7
M Electrical car is possessed please help was supposed to leave for a 1200 mile trip tody Fox 5.0 Mustang Tech 3
C PLEASE HELP 2010 GT losing power. 2010 - 2014 Specific Tech 4
8 Engine need help car has a hiccup Fox 5.0 Mustang Tech 7
7991LXnSHO Engine Car at mechanic, need second opinion info to help get it home Fox 5.0 Mustang Tech 13
W 1996 gt noob with cars needs help please 1996 - 2004 SN95 Mustang -General/Talk- 0
C Need help with first car 2005 - 2014 S-197 Mustang -General/Talk- 2
ponyrde2010 Engine Help, car needs check up, sitting for awhile 2005 - 2009 Specific Tech 0
S Is my car doomed? Bought it like this.. RIP FRAME? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
J Car Doesn't Start Appreciate Help Fox 5.0 Mustang Tech 9
G 92 Fox, Tons Of Changes To A Previously Running Car.....no Start, Need Help Fox 5.0 Mustang Tech 10
GetOuttaDodge Anyone In Eastern Nc Who Can Help? The Welcome Wagon 4
R Need Advice On Project Mustang 1965 - 1973 Classic Mustangs -General/Talk- 7
T I Need Help Putting Tragically Modded Car Back Together 1996 - 2004 SN95 Mustang -General/Talk- 5
V Advice On My New Car! Please Help! 1996 - 2004 SN95 Mustang -General/Talk- 3
M Car Not Staying On? Help Fox 5.0 Mustang Tech 10
R Car Stalls And Dies Very Often SN95 V6 Mustang Tech 10
O Car Has Reverse, But Problems With Forward Overnight? 1965 - 1973 Classic Mustangs -General/Talk- 2
V Fox Need Help Finding A Car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
F Humming In The Front Left Of Car 2005 - 2014 Specific V6 Tech 0
stangboy Help!! My Car Keeps Killing Coils! Fox 5.0 Mustang Tech 8
93silverlx50 Need Help, Car Wont Start, I've Gone Through Both Checklists Fox 5.0 Mustang Tech 54
J Please Help! I Can't Get Car Running SN95 4.6L Mustang Tech 1
D Help V6 Car Hi Performance Ideas Of Grandure 1974 - 1978 Mustang II Talk & Tech 4
